LG LSC183VMA Split System Air Conditioner Logo
Posted on May 13, 2008
Split AC model 2004 LSk1862QCW Remote control is out of order .Complaint no.W8C43000151 dated 30.04.2008.No respose from service centre for replacement of Remote
I am S.P.Aterkar ,from Bhopal,lodged complaint about non working of my Split Ac 2004 model.Complaint No.W8C43000151 lodged on 30.04.2008.Remote control not yet received.such a big company is not in a position to make available remote control.This situation willcompell us not to buy a LG product.
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Jun 05, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
2813
Points
7
And your solution to this problem is to post on a website rather than to complain to the company.
H4 error code is shown on AC display what can i do to slove this problem
Full list of Gree Air Conditioner Mini Split Units Fault Codes. When error codes appear on the Gree air conditioner indoor display, this tells the user there is an issue with the Gree AC unit. The error code displayed will inform you of the issue or problem that is occurring with the air conditioner. Knowing what the error code means and its definition will help you to understand and troubleshoot the exact Gree air conditioner part that needs to be fixed, cleaned, repaired, or replaced. You can then clean, fix, or replace the Gree part yourself and save money. See below for all error codes that can occur on Gree Mini Split AC's.
Gree Mini Split Air Conditioner Error Codes - How To Fix
Gree Viero AC Mini Split PDF Owners and Troubleshooting Manual
GREE DUCTLESS AIR CONDITIONING & HEATING SYSTEM INSTALLATION MANUAL
Gree Mini Split Air Conditioner Part Names and Locations
INDOOR AND OUTDOOR UNIT
The Gree Air Conditioning Vireo System has onboard error code diagnostics. The outdoor unit will provide status indicators and the indoor wall unit and remote control will display error codes. The following is a summary of the codes with explanations...
GREE AC DIAGNOSTIC ERROR CODES
Gree Vireo Mini Split Air Conditioner Error Code F0
Refrigerant Leakage Protection
1) Refrigerant leak(s).
2) Indoor coil temperature sensor not calibrated.
3) Refrigerant flow is restricted (ex. valve, exv, debris)
Outdoor Unit Red Light Indicator - 9 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E1
System High Pressure
1) Over charged with refrigerant.
2) Blocked or dirty outdoor coil.
3) Extreme outdoor ambient conditions
Gree Vireo Mini Split Air Conditioner Error Code E2
Indoor Anti-Freeze Protection
1) Low return airflow.
2) Indoor fan speed is too low.
3) Indoor coil is blocked or dirty.
Outdoor Unit Yellow Light Indicator - 3 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E4
Compressor High Discharge Temperature Protection
Please refer to the malfunction analysis (discharge temperature, overload) in service manual.
Outdoor Unit Yellow Light Indicator - 7 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E5
Overcurrent Protection
1) Supply voltage is unstable.
2) Supply voltage is too low and system load is too high.
Outdoor Unit Yellow Light Indicator - 5 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code E6
Communication Malfunction
1) Communication cable is wired incorrectly between indoor and outdoor units.
2) Indoor or Outdoor control board malfunction.
Outdoor Unit Yellow Light Indicator - Continuous On
Gree Vireo Mini Split Air Conditioner Error Code E8
High Temperature Resistant Protection
1) Incorrect refrigerant charge level.
2) Refrigerant metering device malfunction.
3) Compressor malfunction.
Outdoor Unit Yellow Light Indicator - 6 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code EE
EEPROM Memory Malfunction
Control board malfunction.
Outdoor Unit Yellow Light Indicator - 11 flashes and 1 sec Off
Gree Vireo Mini Split Air Conditioner Error Code C5
System Configuration Malfunction
1) No jumper cap inserted on the control board.
2) Incorrect or damaged jumper cap on control board.
3) Indoor and outdoor units are not compatible.
Gree Vireo Mini Split Air Conditioner Error Code Fo
Pump Down or Gathering Refrigerant Status
Optional Service Mode
Outdoor Unit Yellow Light Indicator - 17 flashes and 1 sec Off
NOTE: All of the Gree Air Conditioner Model Numbers below are applicable for the error codes on this page...
Gree AC Vireo Models: VIR09HP115V1A, VIR12HP115V1A, VIR09HP230V1A, VIR12HP230V1A, VIR18HP230V1A, VIR24HP230V1A, VIR30HP230V1A, and VIR36HP230V1A.
Gree Mini Split Air Conditioner Error Code Charts
Gree Mini Split AC Remote Control Button Names
Gree Mini Split AC Remote Control Icons Display Screen
Gree Mini Split Air Conditioner Air Filter Cleaning Procedure
Need help with error codes on your Gree AC? Please leave a question below and we will be happy to help.
An order I placed and have received no confirmation on but money has been removed from account
Reach out to their customer care unit/service/support centre and lodge complaint asap.
For your account, take another look at your checkout page; there ought to be an order id
From your bank statement, you ought to see the transaction details (amount debited, by who, for what, time, date)
Www samsung com register
Send a complaint to consumer protection forum.
1helpful
How can i get my key remote to lock my car it has a new battery plz reply asap. just need to know how to reset it
TECHNICAL SERVICE BULLETIN
Bulletin Nbr. 831-2429
Date: January 2004
Market: all
Remote control does not work
Cars affected
- 9-3 (9440) 4D M03-M04 within Vehicle Identification Number range 31045482 - 41021353
- 9-3 (9440) CV M04 with column integration module (CIM) 433.92 MHz, within Vehicle Identification Number range 46000001 - 46006859
- 9-3 (9440) CV M04 with ESP and column integration module (CIM) 433.92 MHz, within Vehicle Identification Number range 46000001 - 46006710
- 9-3 (9440) CV M04 with column integration module (CIM) 315 MHz, within Vehicle Identification Number range 46000001 - 46009855
- 9-3 (9440) CV M04 with ESP and column integration module (CIM) 315 MHz1 within Vehicle Identification Number range 46000001 - 46009843
Background
Under certain circumstances the remote control receiver, which is located in the CIM, may cease to function. The software in the column integration module (CIM) must be updated so that the remote control operation achieves full functionality.
In the case of customer complaint the following procedures must be carried out.
Symptom description
The car cannot be locked or unlocked using the remote control.
Procedure
Before any action is taken, check if the deficient functionality of the remote control receiver is due to incorrect software:
^ Check if the fault is due to the loss of synchronisation between the remote control and the car.
- Insert the key into the ignition for at least 2 seconds.
- Does the remote control work?
YES: Updating the software, in accordance with this TSB, does not rectify the fault.
NO: Continue to check as follows
^ Remove fuse F2 from the dashboard electrical centre. Wait for at least 5 seconds.
^ Fit fuse F2.
^ Does the remote control work?
NO: Updating the software, in accordance with this TSB, does not rectify the fault.
YES: Update the software in the CIM.
Where can I get a remote for a Model ASORD18DA Ductless and a service manual.
Hi; Look in the Yellow Pages for Your local ac supply house they can order it for You or point You to the manufacture for assistense...alpharome416
Power went off while ac was running. Now ac will not run. Has a wall mounted controller with a hand remote.
if it is a mini split you have to set date and time on remote before unit will work remove batteries from remote and start over
4helpful
3answers
2answers
AC remote not working
www.gree-ac.com this is gree website you will need a model and serial number from unit I would contact them to see who your local suppliers are or online order remote m# and s# would also help if available
Top LG Heating & Cooling Experts
Mike Cairns
Mike Cairns
MattS1978
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
