Control Module
ID Number
Body Control Module (BCM)
064
Electronic Brake Control Module (EBCM)
040
Instrument Panel Cluster (IPC)
096
Radio
128
Powertrain Control Module (PCM)
016
Sensing and Diagnostic Module (SDM)
088
Diagnostic Aids
When a malfunction such as a open fuse to a module occurs while modules are communicating, a Loss of Communication DTC is set as current. When the modules stop communicating, ignition is turned off, the current Loss Communication DTC is cleared but the history DTC remains. When the modules begin to communicate again, the ignition is turned on, the module with the open fuse will not be learned by the other modules so U1000 or U1255 is set current by the other modules. If the malfunction occurs when the modules are not communicating, only U1000 or U1255 is set.
Test Description
The numbers below refer to the step numbers on the diagnostic table.
The switched battery positive supply circuits
The battery positive voltage output circuits
The ignition voltage input circuits
The ignition voltage output circuits
Refer to the following:
Control Module References in Body Control System for the applicable schematic
Circuit Testing in Wiring Systems
Wiring Repairs in Wiring Systems
Did you find and correct the condition?
5
Important: Inspect all connectors in the serial data communications circuit.
Data Link Connector Schematics
Testing for Intermittent Conditions and Poor Connections in Wiring Systems
Connector Repairs in Wiring Systems
Go to Step 8
Go to Step 6
6
Inspect the harness connector of the module that is not communicating for poor connections and terminal tension at the following circuits:
The battery positive voltage input circuits
The switched battery positive voltage supply
The ground circuits
The class 2 serial data circuits
Go to Step 8
Go to Step 7
7
Important: Perform the module programming or setup procedure if required.
Replace the module that is not communicating. Refer to Control Module References in Body Control System for the appropriate Repair Instructions for the module replacement.
Did you complete the replacement?
Go to Step 10
8
Does the scan tool display any DTCs which do not begin with a "U"?
Go to Control Module References in Body Control System for applicable Diagnostic System Check
Go to Step 9
9
Use the scan tool in order to clear the DTCs.
Did you complete the action?
Go to Step 10
10
Select the Display DTCs function for the modules which had U1000 or U1255 set as a current DTC.
Does the scan tool display DTCs which do not begin with a "U"?
Go to Step 11
11
System OK
12
Did you record any other DTCs for the modules which had U1000 or U1255 set as a current DTC?
Go to Step 13
13
