1997 BMW 328 Logo
Posted on Aug 27, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to disable my alarm on a 1997 bmw 528i.
Anonymous
Level 3:
  • Master 864 Answers
  • Posted on Aug 28, 2010
Anonymous
Master
Level 3:
Answers
864
Questions
0
Helped
223693
Points
1873
Now im not sure since the manual says your model has the same alarm system as the 328i and on the 328i you can remove the module to disable by doing the following. you can unplug the control module. It is located under the glove box. Climb under the dash on the passenger side and remove a few screws on the trim panel under the glove box. Theres a black control module with a green connector. There should be a lock tab on the connector. press the lock tab and pull out the connector. The alarm should now be disabled. But if it has the special transponder key this may not work.
But if the only reason you want to disable it is because of the motion sensor setting of the alarm for no reason there is a solution for this. To disable the motion sensor, hit the lock button to arm, then hit lock button again within four seconds to disable motion sensor. Red light on rearview mirror should flash four times, then pause, then start flashing on regular intervals. this is most likely the reason if your having the issue where the alarm goes off every 20 minutes.
If you want to completely remove it below is a wiring diagram taken from the manual for you alarm system.
this is from the manual its the alarm wiring diagram.
Battery Constant 12v Positive Wire ( ): Red/White or RedBattery Constant 12v Positive Wire Location: Ignition Switch Harness
Starter Positive Wire ( ): Black/Yellow or Black
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire ( ): Green
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire ( ): Purple/White or Purple
Second Ignition Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire ( ): Gray/Purple and Gray/Yellow. Use Both Wires. This vehicle has a dual parking light system that will require 2 extra relays.
Parking Light Positive Wire Location: At Headlight Switch
Power Door Lock Positive Wire ( ): White/Red
Power Door Lock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Power Door Unlock Positive Wire ( ): Blue/Red
Power Door Unlock Positive Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Door Trigger Negative Wire (-): Brown/Gray
Door Trigger Negative Wire Location: At Factory Alarm Plug. The alarm plug is a black 12 pin plug located just behind the glove box.
Domelight Supervision Wire: Turns On With Unlock
Domelight Supervision Wire Location: N/A
Horn Negative Wire (-): Brown/Red or Brown/Yellow
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): Black
Tachometer Wire Negative Wire Location: At Instrument Cluster
Brake Light Positive Wire ( ): Blue/Red or Green/Red
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): Disarms With Factory Remote Only. Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: Transponder Anti-Theft System, Requires Bypass And Extra Ignition Key. The 1997 model year vehicle may require a bypass module and an extra ignition key, if vehicle is equipped with a special key from BMW.
Factory Anti-Theft System Location: Transponder At Ignition Switch Tumbler
if you require further assistance please let me know and i will help assist you from there. Thanks, Midwest-Tek
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Dec 03, 2011
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
4399
Points
My ignitoin lights somtimes wont come on when i try to start my bmw 328ci can you help me please thanks
Anonymous
Level 3:
  • Master 4,793 Answers
  • Posted on Aug 27, 2010
Anonymous
Master
Level 3:
Answers
4793
Questions
0
Helped
1544783
Points
14368
If its a factory alarm you CANNOT.if its a clifford or another make GOOD LUCK...you will need the wiring diagram for the maker and believe me its not a job i would undertake...WHY....
BMW1998 528i, alarm goes off for no reason. Have to keep car unlocked to disable it. Is there a fuse or something I can disconnect to stop the alarm from going off?
At this website www.reliable-store.com I found
all complete guide, much better language, complete detail in 800+ pages, and they also have live assistance feature
Cant open the trunk on 1997 e39 BMW 528i
you should be able to tip the rear seat you should be able to trip the lock but check for a release cable around the rear deck, much easier
Where can i find a free wiring diagram for a 1997 bmw 528i
Visit the following website, they advised that they offer free radio stereo wiring diagrams for free, including Nissan. http://www.modifiedlife.com/1997-nissan-pathfinder-car-radio-stereo-wiring-diagram/------------------------------------------------------------------------------------------
FGtech V53
8helpful
2helpful
97 BMW 528I NEED DRIVE BELT DIAGRAM
My sincere apologies for the delayed response.
I am personally going back to answer your unanswered questions.
I do not know if you still need this information, but I am going ahead and answering it anyway. You may want to Print the Diagrams for future use.
CLICK
on the following LINK. It has the Belt Diagrams you will need.
If you would: Before Clicking: Let me know if this helped you, or if you have any additional information or questions. Feel Free to contact me at FixYa.com!
Again my apologies...
http://www.2carpros.com/car_repair_information/year/1997/make/bmw/model/528i/1997_bmw_528i_drive_belt_routing_diagram.htm
Put in a new wiper motor 1997 e39 528i bmw\it stops in the middle
Remove arm(s), put wiper motor in park,(shut off) then re-install arm at base of windshield where they were before,when shut off.(in park position.)
The rear passenger window on my 1997 BMW 528i stuck in the open position. I heard a cable snap and need to get it repaired, but would like to know how to remove the inside panel so that i can prop up the...
you need a cable kit replacement. 25 bucks.
google: 1997 BMW 528i regulator repair kit. 97's and 98 are the same, 99's are diff. the same clip breaks in all of them. this guy has invented a permanent fix for it. same work repairing as replacing, only difference is that after repairing it, it wont break again!
97 bmw 528i factory alarm goes off for no reason
disable the hood microswitch. just unplug it. That and the cabin sensor are the most probably reasons the alarm will go off.
Alarms are useless. Totally effin useless. So it goes off.....then whaddya going to do. Shoot someone? Call the police? or listen to it drain the battery over and over again.
But....you can't disable the alarm totally. The bmw engineers have tied it into the main computer. you can however disable the sensors one by one so it doesn't set off the alarm. Hood sensor....Hood sensor....that's the culprit.
1helpful
97 bmw 528i
unfortunately, it sounds like you need a new transmission 200k is very good, you may try to find a rebuilt one.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
