Microwave Ovens Logo
Posted on Aug 20, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the F4 error fault in GE micro oven - GE Microwave Ovens
Anonymous
Level 3:
  • Master 1,998 Answers
  • Posted on Aug 20, 2010
Anonymous
Master
Level 3:
Answers
1998
Questions
0
Helped
620836
Points
5972
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor hope this helps please remember to rank how this opinion helped in your appliance situation have a great day if i can answer any futher questions please message me back have a great day
rickead1
My GE Spacemaker microwave flashes F4 when I want to cook fish. What should I do?
"F4" on a GE microwave means you have a failed humidity sensor.
You can get GE parts by searching by model number here.
If you have other questions, please contact me directly since FIxYa doesn't always inform us of follow-up questions.
I would need to know the full model number from the tag on it, and the FCC ID number can be helpful, too.
- William E. Miller, AS-EET
[email protected]
http://www.MicrowaveControl.com
Microwave Oven Control Panel Repair Nationwide "Recycling by repairing since 1982"
Why does my GE Spacmaker display an error code F4 without turning on microwave whatsoever?
If you wish to get some details microwave repair and Error codes ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
What does F4 mean for the GE Micro JEM31
"F4" on a GE is normally a defective humidity sensor.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
See these files for disassembly help:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
1helpful
Error Message F-5
F4
or
F5 Humidity sensor open or shorted Replace humidity sensor.
We have a ge 1860 micro wave oven and it is not heating, after a period of time it indicates sensor error, can you help me.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
]0]0]0]0]0]0]0]0]0]0]0]0
5helpful
F5 error code
F4
or
2answers
My GE JES1656 will not work. Check the fuses and nothing blown on the panel. Tried other appliances in the same outlet and they work. Microwave oven is about a year old...any fixes??
Probably the "oven temp/flame sensor" if you make microwave popcorn and the vents on the left hand side are restricted. Gets pretty hot. This part cannot be reset and has to be replaced.
6helpful
2answers
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
''Press Clock'' but can't press buttons, then beeps with F4 error
F4
Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor
2helpful
2answers
New GE Microwave JVM1750DM1BB with F4 error in Sensor cooking
GE
Microwave Fault Codes Failure
Code
Condition Check/Repair F1 Open sensor, will occur below 190F of cavity temperature within 15 minutes after starting convection, combination or roast cook Check oven temperature sensor for continuity. Replace if zero or infinite ohms F2 Shorted thermal sensor, will occur if a shorted thermal sensor is detected continuously over 5 seconds on convection, combination or roast cooking Check oven temperature sensor for continuity. Replace if zero or infinite ohms
Note: It will take a minimum of 5 minutes of convection run time before F1 or F2 code will be displayed if the thermal sensor is shorted or open. F3 Shorted key panel (touch pad), will occur if a shorted key panel is detected continuously over 60 seconds Replace key panel (touch pad) F4 Open humidity sensor, will occur if humidity sensor is detected as being open continuously over 5 seconds Replace humidity sensor F5 Shorted humidity sensor, will occur if humidity sensor is detected as being shorted continuously over 5 seconds Replace humidity sensor F6 Shorted temperature probe, will occur if temperature probe is detected as shorted continuously over 5 seconds Replace temperature probe ProbEe Open temperature probe, will occur if temperature probe is detected open, or not plugged into the receptacle If probe is plugged in and "ProbE" is on display check continuity of the probe with an ohm meter. If zero or infinite ohms, replace it
Top GE Microwave Ovens Experts
vince
NOEL
NOEL
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
