Hotpoint 24 in. FDW60 Free-standing Dishwasher Logo
Posted on Apr 30, 2008
Hotpoint FDW60 problem
My dishwasher has started to wash for hours, even on the 25 minute fast wash option it just keeps washing. I need to switch the power off just to stop the wash, then select the rinse and try options manually. Has my timer gone?
Anonymous
Level 1:
Problem Solver:
  • Contributor 7 Answers
  • Posted on May 18, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
7
Questions
0
Helped
4825
Points
15
Hi
you will proberbly find that you have a control module fault.
connection from you heater and or thermostats faulty.
if your heater was open curcuit it would flash fault codes.
1helpful
Fdw60 is flashing fast and delicate lights
The code is a10 this is normally a heating issue but could also be a foaming problem which could also be your poor washing results put a cleaner through with a lime scale remover
Please help I have a aquarius FDW60 . The problem
It is likely the flood switch at base of dishwasher has activated due to a leak.
You will have to dry the leak and then try again.
Make sure the mains power is shut when you are working on the dishwasher to avoid electrocution.
11helpful
2answers
Hotpoint FDW60 flashing eco light
if the eco light is flashing, this indicates that saftey float switch has activated in the base of the dishwasher usually caused by a leak, a polystyrene float activates a microswitch which cuts of the water inlet supply
2answers
FDW60
I have exactly the same problem, please let me know if you find a solution and I will do the same.
2answers
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Hotpoint dishwasher fdw60
the fault wasn't with the machine. we got new waste pipes put in and the conection for the dishwasher hose didn't have the hole for the water to release. thank you for your help
1helpful
HOTPOINT DISHWASHER FDW60
I have just had my dishwasher fixed by Hotpoint, as the heater was working and the dishwasher only stopped with the fast and delicate lights just before the drying process he replaced the main control board. This has solved the problem, I suspected the fault to be the thermistor as the heater seemed to be getting to hot but I had no idea where it was.
It turns out the thermistor is attached to the main control board and hangs down behind the front door that gives just a rough temperature level for the main control board.
As it's soldered directly onto the control board I would suggest replacing the whole control pcb for anyone with this fault unless you can find any spec details for the thermistor.
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
