Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Starting the Appliance
Insert the plug into the wall socket. The green pilot light will illuminate to show that the appliance is switched on. The red alarm light will also illuminate until the freezer reaches the correct temperature.
Alarm Light
The red alarm light will illuminate when the temperature in the freezer is higher than the thermostat setting. This alarm light will illuminate if:
- The appliance has just been started.
- Fresh food has been put in the freezer.
- The lid has been left open, opened frequently or open for too long.
The red light will go out when the freezer has returned to the correct temperature
If you press the SUPER button than you start fast freeze function and yellow light will illuminate.
I assume that the freezer is on and the green light is illuminated. This means that the freezer is on and energized.
Also, if freezer does not cooling, means that did not achieve the set temperature should be illuminated the red light (alarm).
Set the thermostat for example in position 4th and after that compressor should be start.
If compressor running but not cooling, defective is the system which circulates gas.
If compressor does not start, then is faulty thermostat, compressor or the wiring.
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
Is this just a "Power-on" light to let you know it's plugged in and has power? This is probably just a "neon" (although the actual gas inside is hydrogen for the green color) bulb and sometimes they will do the flickering thing literally forever. In a way it's a good thing as it makes you look at it. If it really concerns you, or if it is actually a warning that something is going wrong (it should say in the manual, you DO have the manual don't you?) have it fixed under the warranty.
