20 Most Recent Zanussi 3.53 cu. ft. / 100 liter Upright Freezer ZUD9100F Questions & Answers
Why does the red light on my VF70 freeze r stay on all the time?
Warning light (red) If the temperature warning light ? lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food. 24341613-zd1td1vvrl1llkwzbg5ljqsk-5-0.jpg Dado
10/4/2015 7:17:21 PM • Zanussi 3.53 cu.... • Answered on Oct 04, 2015
No alarm sounding but red light is flashing?
Warning light (red) If the temperature warning light (4) lights up, it indicates that the temperature within the freezer has reached a level where the safe food storage is no longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to a safe level for the storage of frozen food. Temperature acoustic alarm This appliance incorporates an alarm which gives off an audible signal whenever the warning light comes on. This signal can be temporarily stopped by depressing the push button for fast-freezing (6). The fast-freezing push button can be released as soon as the warning light is off. Open door acoustic alarm This appliance also incorporates an alarm which sounds if the door is left open for more than 60 seconds. The signal will be stopped when the door is closed again. Dado
1/8/2015 8:38:59 PM • Zanussi 3.53 cu.... • Answered on Jan 08, 2015
After defrosting the freezer would not restart, it
over load and relay
5/5/2010 5:03:46 PM • Zanussi 3.53 cu.... • Answered on May 05, 2010
Warning alarm and light
it will do that till temp is reached
10/20/2008 11:57:32 AM • Zanussi 3.53 cu.... • Answered on Oct 20, 2008
2answers
Hotpoint quadrio fridgefreezer keeps tripping the electrics when I open the fridge door.
I believe that a short circuit creates a defective light bulb inside the refrigerator or some other element in its circuit (door switch, lamp socket, wiring). Dado
12/21/2016 8:33:13 PM • Zanussi Freezers • Answered on Dec 21, 2016
How to add refridgerant gas to an lg fridge freezer
For such a procedure you should have knowledge and a lot of expensive work condition like: - Vacuum pump - Charging station - Manifolds - Recovery station - Electronic charging scale - Electronic leak detector or UV leak detector and so on ...... The situation is further complicated by some of the new environmental gases which are explosive so you need to be qualified and trained person. It is best to leave that to the specialist or qualified service personnel. Dado
1/16/2015 7:43:04 PM • Zanussi Freezers • Answered on Jan 16, 2015
Zanussi freezer Zut 6246. Superfreeze button won't go off
Probably is switch for fast freezing mechanically defective. Dado
1/16/2015 7:23:45 PM • Zanussi Freezers • Answered on Jan 16, 2015
Why is the red light flashing on my zft810fw freezer when it is freezing ok inside
Under normal operating conditions, the internal temperature of the freezer will ensure the longterm conservation of the stored food. When such temperature rises above a certain level (-12 °C), the appliance will trigger an acoustic and light alarm. The light alarm is a blink red light (Red Alarm Indicator Light), while the acoustic alarm is an intermittent sound. You can stop the acoustic alarm by pressing the Acoustic Signal Stop Switch once. When switching on the freezer for the first time, the Red Alarm Indicator Light will blink until the internal temperature has reached a level required for the safe conservation of frozen food. Dado
1/16/2015 7:15:34 PM • Zanussi Freezers • Answered on Jan 16, 2015
Why is Zanussi frost free freezer alarm always flashing
Because it does not achieve the correct temperature (for example: -18 degrees centigrade). For a more precise answer I need more information. A lot of things may be incorrect: - Doesn't work defrosting cycle - The cooling fan is not working - Too much ice on the evaporator battery - Faulty thermostat or NTC sensor - Faulty cooling system (gas leak) - Compressor - Electronic Dado
1/16/2015 7:06:14 PM • Zanussi Freezers • Answered on Jan 16, 2015
Door will not close
It sounds like the door got shut when something in the jam and you may need to loosen the hinge, realign the door and tighten the door hinges again. Easier with 2 people but not impossible with 1.
3/3/2014 11:17:33 AM • Zanussi Freezers • Answered on Mar 03, 2014
2answers
Our freezer has devoloped a problem in that it
the unit was still wet inside when you switched on the fast freeze,hence the frost and ice.
1/21/2013 8:54:15 PM • Zanussi Freezers • Answered on Jan 21, 2013
0answers
Zanussi 3.53 cu. ft. / 100 liter Upright Freezer ZUD9100F Logo
10 questions posted
Top Zanussi Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Zanussi Freezer Expert? Answer questions, earn points and help others
View Most Popular
Zanussi Freezers
  • Zanussi Freezers
Most Popular Question
after defrosting freezer not restart
  • Freezers
