Pyramid CDR49 We have this radio in an rv. and it will not come on. We checked the wiring and find no problem. Is there a place near us that can check out the problem We live near Raleigh, N. C.
The light switch for the outdoor light on your 2012 Keystone Avalanche 345TG may be located in a few different places, depending on the specific configuration of your RV. Here are a few places you may want to check:
Inside the RV: The light switch may be located near the entrance of the RV, on the wall near the door or in the main living area.
Outside the RV: The light switch may be located on the exterior of the RV, near the door or on the side of the unit.
In the electrical panel: The light switch may be located in the electrical panel, which is typically located inside the RV, near the front or rear of the unit.
If you are unable to locate the light switch, you may want to consult the manual for your specific model of Keystone Avalanche or contact the manufacturer or a qualified technician for assistance.
I hope this information is helpful. Let me know if you have any other questions or if there is anything else I can assist with.
limited information generic answer unknown chassis chevy or ford this link will give chassis info when open click on radio wiring and look up chassis if rv system a rv dealer --rv shop --or rv forumn https://www.modifiedlife.com/
run rca cables and a remote wire from your radio to the amp,run a power wire from your battery and attatch a ground to the car ,then hook up the wires and cables to there respective places.
The wires should just attach to the red and black terminals on the radio, strip some wire unscrew the terminals a little wrap behind, and tighten again. Good luck! Or buy some banana plugs and they will plug right in the front
red - power Black - Ground Blue/Black - rear Left Speaker Positive Blue - Rear Left Speaker Neg White/ Black - Front Left Speaker Positive White - Front Left Speaker Neg Brown/Black - Rear Right Speaker Positive Brown - Rear Right Speaker Neg Yellow/Black - Front Right Speaker Positive Yellow - Front Right Speaker neg Green - Left Input Positive Green/White Left input Neg Gray Right Input Positive Gray/White - Right input Neg
