20 Most Recent
Pyramid (Swr14) Swr&Power Field Strength Meter with Power Switch (10&100 Watts) Questions & Answers
I have one of these
This unit was designed for cb operation only, using it in the two meter band range will cause unstable readings and accuracy issues and risks overloading the rf finals. I strongly suggest a proper ham unit for calibrations.
What is the value of the resistor that burns up
Hi wrightjc2,
Most common burned resistor are those with low resistance because it acts like a fuse to avoid further damaged to some parts if shorts,overload happened. But still best to have a schematic diagram to identify the burned one. If you haven't a schematic you may get the resistance of the resistor, measure it to the middle where the burned cut out, add the resistance from one half side to other half side. You may now have an Idea what may be the value of the burned resistor.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
What is a pyramid schemes?
Hi Linda, It's called a pyramid because it starts with one person putting money into a fund, Say it's a guy, He then invite as many people as he can(say 10) to do the same and then those 10 people invite as many as they can(say 10 each x10=100) and so on100x10=1,000) and on(1,000x10=10,000)... see how it grows... And what happens is the 1st guy gets a percentage of the money from the 10 people he invites plus a percentage from the 100 people they invited and it goes on and on, , the people he invited get a percentage of the people they invite plus a percentage from the people they invited and so on and on and it just keeps going and going and the higher on the list you are the more money you get but the lower on the list you are the more you struggle as it gets harder and harder to make money because everybody above you on the list are all getting a percentage from people all down the list until eventually everybody on the bottom of the list looses all their money and that's why it's *******......DO NOT DO IT, If you make any money from this scheme just know it's from people loosing theirs, Take care.........
