HP Inkjet 1200dn Printer Logo
Posted on Aug 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Printer hasn't been used in a yr just replaced all new ink have cleaned the heads as well as print heads when trying to print a test page it goes all through the motions but nothing on the paper thanks for the help im going crazy over this
Anonymous
Level 3:
  • Master 1,138 Answers
  • Posted on Aug 10, 2010
Anonymous
Master
Level 3:
Answers
1138
Questions
Helped
432831
Points
3620
Even if you clean the print heads and replace old inks there are still dry ink that is clogging the ink ways of the cartridge.
You may flush it with tap water to let the ink flow out.
here is the procedure to do that.
....Open your printer cover, remove the cartridge..place the printhead directly on a tap water running slowly. This will help flush the dried ink that clogged in the printhead. Turn the print head over, bottom side up until you see the ink flowed out from the printhead, do this until you see the a smooth flow of ink..(better result if the water is warm).. tap water contains residual minerals that can clog also the printhead..so it is advisable to final flush the printhead with a distilled water (it has no impurities) and dry it with cloth..
The last thing to do and it will take you sometime is to soak the printhead portion of your cartridge in a mixture of ammonia and hot distilled water, (please make sure that the contact point of the cartridge to the printer is not soak).. Place the printhead on the hot water and leave it there for about 4 to 5 hours..move it on different location from time to time..After soaking, rinse it with distilled water and dry it with cloth...
After doing the instructions, return back the cartridge to the printer and do the printhead alignment..
Try printing a test page and see the outcome...
Anonymous
Level 1:
New Friend:
  • Contributor 22 Answers
Anonymous
Contributor
Level 1:
New Friend:
Answers
22
Questions
0
Helped
5465
Points
66
Your print heads are probably bad. Best solution is to buy a new printer. The cost on the print heads is more than the machine is worth.
Clean printer heads
Several ink based printers have a built in cleaning process. The printer will move the print head carriage assembly to a cleaning station that uses some ink to lubricate/wet the print head to loosen old ink. It lets it soak for a couple seconds and wipes it off. After the cleaning process some printer will do a test page or even calibrate colors. If a print head is too clogged up or the inkjet too clogged the cleaning process will not work then you will need to replace the print heads. May times you can not get replacement print heads for brands beyond Brothers or HP plotters so you may need to obtain a new printer.
Printer Repair Service in Miami and Fort Lauderdale FL
Why is Kodak printer printing bank pages when ink ull
You might have a printer head problem or a technical problem. Go through these steps and make sure that you not low on ink.
1. unplug for a few minutes and re-plug, try printing. if not working,
2. Do a printer head cleaning function, if not working,
3. Remove printer head, clean it, put it back and try again, if not printing, then
4. If you have a spa
re printer head, try that one and see if it prints. if it prints, get a new printer head.
5. If after cleaning printer head you tried a test page and failed to print and printer head is totally dry, first try cleaning the contact area with alcohol solution or use a printer head cleaning kid if you have one but don't invest a lot of time and money in buying cleaning material.
6. If all failed, your printer has a technical problem you cannot resolve, call Kodak support and ask for possibility of a free replacement. They may ask you to upload "data diagnostics" under printer tools and if the problem confirms, they may agree to send you a new replacement. Good Luck.
1helpful
I just inserted new ink jets into my Canon MP 490. When I request a print test page, it goes through the motions but the page is blank.
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
5helpful
2answers
Most of Group 1inks,(except red) won't print
Over on the right is not waste ink pads, waste ink is under the print engine covering the whole bottom of the printer. On the right is the purge assembly and there is ink on the filters on top and on the squeegee that wipes the printhead. You may need a new purge assembly, or just re attach a hose in the purge unit that may have come off. That printer is well worth the repair...
Canon i960 prints but no ink on page-new printhead (not clogged)
Sounds like the print head is no good. This happens. Here's a link to a site that sells them reasonably.
3helpful
2answers
New cartridge won't print
  1. Make sure you removed the tape from the ink cartridge.
  2. Press the <Menu> button on the printers operation panel.
  3. Press the left [<] or right [>] arrow buttons to select [MAINTENANCE].
  4. Press the <Set> button.
  5. Press [<] or [>] to select the cleaning setting you want. Select [HEAD CLEANING] for normal print head cleaning. Select [HEAD REFRESHING] for deep print head cleaning.
    Note: [HEAD REFRESHING] uses more ink than [HEAD CLEANING], so perform [HEAD REFRESHING] only when necessary.
  6. Press <Set>.
  7. Print a Nozzle Check Pattern and perform at least two Head Refreshing if the pattern is not correct.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
No ink on page
Clean the contact in the housing area and on the ink cartriage. If that does not work buy a new cartriage. The ink probably dried up in the nozzles. You can place the ink cartriage on a wet paper towel water or alcohal and press the cartriage into the towel. If you see no ing replace.
3answers
Not printing even the test page,full ink ??
I have the same problem, I re-loaded the software, checked all the settings, went through set up procedures and nothing??????? I goes through all the motions, spits out the paper..........blank
Blank printout
If you are able to drag out your users manual, most lazer printers have a self cleaning process for the head, which takes around 3-5 minutes to complete, after that try to run a test page to ensure the colors are working fine.
Failing that, unless the printer is brand new, and or unless it has been sitting ( unused - regardless of age ) the print heads can dry out leaving a blockage ... hence, no ink, hence blank page.
The only other suggestion after running a Print head clean, would be to replace or refill the ink cartridges.
Canon BJC 4300 InkJet Printer
i assume the cleaning method that you perform is offline (taking the cartridge our and clean them). I suggest you clean the head during the printer on.. try to perform below steps per the manual Cleaning the printer Printing the test pages Cleaning the print head I assume you do not have the manual anymore (no DVD) i list down the step below Its a bit long manual I suggest you download them from the canon website.. if you still have problem I can send to you the BJC 4300 manual Cleanning printer Make sure the printer is turned off before cleaning it. It is a good idea to unplug the AC adapter also. Do not clean the exterior of the printer with volatile liquids such as thinners, benzine, or any spray-type or chemical cleaners; doing so will damage the surface of the printer. When cleaning the printer, avoid the area near the print head on the BJ cartridge. Do not touch the print head. Ink may leak out and cause stains. Clean the printer regularly to avoid printing problems. Remove any ink mist or paper debris from the interior of the printer using a soft cloth moistened with water. Clean especially well around the platen area. If the rollers become dirty, you can clean them using a small soft brush. Clean the exterior of the printer with a soft cloth moistened with water. Clean away smudges and dust. Do not use paper products (such as paper towels or tissues) to clean the inside of the printer. Printing the Test Pages You can print these test pages to check the operation of your printer and your print quality. Test A This test prints a repeating pattern of characters. Demonstration This test prints a sample page describing the printer's features. Printing the Test Page From Windows You use the Test option on the Control tab in your BJC-4300 Printer Driver for Windows to print a self test, demonstration page, or a nozzle test pattern. Before selecting a Test option, make sure paper is properly loaded in the sheet feeder (see Automatically Feeding Paper starting on page 3-7). Click on the Test option and then click on the Print button. Printing the Test Pages Using the Operators Panel To print a test page, make sure the printer is turned off and paper is loaded. Press and hold the POWER button until you hear the number of beeps that correspond to the test page you want to print. Test Page Number of Beeps Pages Printed Demonstration 1 Continuous Printing Status Information 2 1 Page Test A 3 Continuous Printing Nozzle Test 4 1 Page When you release the POWER button, the test page starts to print. *All self-test prints require Letter or A4 size paper. Using a smallersize paper for a self-test print will result in parts of the printoutbeing printed directly on the platen. All self-test prints are printed in accordance with the current printing settings (font, printing mode, etc.) *Red- Information for technician not included in the user manual Cleaning the Print Head Your printer is equipped with a print head cleaning function to ensure constant high quality printing. Cleaning the Print Head From Windows If you are using Windows, you can execute print head cleaning from the Control sheet in the printer driver. Simply click on Clean Ink Head. 4300 Chapter 4 Page 6 Cleaning the Print Head Using the Operators Panel If you want to clean the print head from the operator panel, follow these steps: 1 Make sure the printer is turned on. Make sure the green POWER light is on. 2 Press and hold the RESUME button for at least two seconds until the printer beeps twice. The POWER light will blink for several seconds while the print head is being cleaned. Perform the print head cleaning only when you encounter a print quality problem. Unnecessary and repetitious cleaning will waste ink. If you execute the print head cleaning while paper is manually loaded, the printer will eject the paper and then perform the cleaning. 4300 Chapter 4 Page 7
k24674
Grand Canyon Tech
Grand Canyon Tech
