20 Most Recent
HP Business InkJet 2800 Printer Questions & Answers
Reset hp2800 1-800-532-4187 SPAM SPAM SPAM
Hard Reset
Remove the cartridges from the printer then unplug the power cable from
the back of the printer and from the walljack wait for 30 seconds then
replug the power cable to the wall out let and then to the printer.
Power Drain
the back of the printer and from the walljack wait for 30 seconds now
press and hold the power button on the printer and replug the power
cable to the wall out let and then to the printer after the power cable
is connected you can let go off the power button..
Configure network
There are no end of problems with HP printer driver software. I've had them too. The most likely success will come from completely UNINSTALLING the present HP printer software (ALL OF IT) and reinstalling the MOST CURRENT PRINTER DRIVER for your computer operating system. You download that driver from hp.com by inserting your model number an following the screen instructions. There is a companion PRINTER DOCTOR tool from HP that you should also download just in case you continue to have a problem after you install the new driver. I can't stress to much how important it is to completely remove all traces of the HP software from your computer first before you reinstall using the latest driver. Failure to do so will cause you continued problems.
Also, if you want to minimize other software issues, after you've downloaded the most recent driver, REMOVE your Antivirus Program if you are using one. I found that there were conflicts caused by Kaspersky AV firewall settings that HP software did not over come. I reinstalled Kaspersky AV after the HP software install and everything worked fine then. The necessity of this step seems to be computer-dependent. I have 3 pcs, all running Win10 Home and only ONE of them required this extreme step in order to get the software to function completely ok.
Why am i getting blank copies from my printer
The chances are good that what U need to do is a printhead cleaning. On the printer if it has a LCD screen scroll through the menus and look for Maintenance or tools and then look for printhead cleaning . It can also be done through the software by going to the top left hand corner of the page U are trying to print and click on the button or File scroll down to print and click on that and that brings up a box with your printer name in it and beside that is a box called properties and look for maintenance or tools there. After the printhead cleaning it will ask if U want to print a test page - say yes if that page looks good -problem solved but it will probably take a few cleanings if U R getting blank pages now. Warning repeated cleanings use a lot of ink so only do what you need to. If after several cleanings U are still getting blank pages U might need to replace the printhead
Mirror image
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image check box.
9. Click OK, and then click Print or OK in the Print dialog box.
Read More.....
HP Printer Support
Thanks,
Printing in a mirror image
try looking under the printer properties in the software and check each section looking for a box that says print Mirror image and if the box is checked uncheck it
Squeaking sound
what weight of paper did you use. Normally 80grms or havier?
