Fossil BQ9184 Wrist Watch Logo
Posted on Apr 23, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fossil blue collection wrist watch, services in hyderabad and cost
I hold a fossil watch , battery down bcos of long time no usage reason.
Now i want to use it and fixit , could you tell me any authorized services near to hyderabad, AP, India (narayanaguda area) and what can be the cost??
I got this watch for 100 USD when I went to US.
thanX
Anil
94904 55112
  • Anonymous Feb 19, 2009
    change of battery and chain for fossil watch
Anonymous
Level 2:
  • Expert 109 Answers
  • Posted on Apr 23, 2008
Anonymous
Expert
Level 2:
Answers
109
Questions
0
Helped
96178
Points
351
You are now way NEAR a center. You will have to go to Fossil.com and find one in a nearby country.
What battery does the fossil fs 3105 watch take
It's actually a lot easier than that video shows. You're trying to represent a watch that is a PDA! To change the battery in your watch, you need to purchase a watch kit on eBay for about $15-$25, purchase the correct battery, watch a realistic video of changing a battery on Youtube, and then you will never need to pay more than the cost of a battery (a few dollars) to change your watch battery ever again! Sending it to Fossil takes time and money and you can do it at home with basic skills!
Battary size for fossil blue watch bq8775
Thanks for contacting Fossil.
The only way to know the battery size is to pull out the old one. It might also be in your manual. It might be on the outside of the watch.
If battery is missing, then you will have to measure the cavity and match it against a battery chart.
Best wishes.
How to take out fossil watch links without breaking it
mcdevito75 here, You"d need a special tool called a link remover tool available on ebay but, the cost and time for delivery are the same as you looking for a small watch repair shop in your area to remove these links for you, hold onto the se removed links just in case you ever want to re-install them.
I have found a fossil watch model BG-2103. I cannot get the back off to change the battery, can you tell me how to get the back off and how much this watch cost.
mcdevito75 here, Look for any Notch in the cover that match a notch in the case, use a knife with a sharp blade and place the knife in the notch and with a slight twisting motion the cover should pop off. Depending on the age of the watch and the functions cost could be anywhere betwwen $25.00----$60.00 Fossil watches are also collectables.
2answers
ES9439 Wrist Watch: what battery doe the Fossil ES9439 Wrist Watch tak...
Link
Please visit above link for your Fossil battery requirement. Kindly contact Customer Service Team for further details.
Thank you.
2answers
I have lost the battery for my Fossil Blue BQ 9039 watch. What battery number should I get to replace it?
To find a registered repair person in your area.
GOTO:
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
For no reason my watch is having a problen on the screen,the number are dessapering. How can I solve this thing?? Thank you
It probably needs a new battery.
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving.
Need a new glass for my fossil watch fossil blue CH2435
This is will take a jeweler or watchmaker to fit with a new crystal.
1st take this watch to the point of purchase and see if they can assist you, sometimes they will surprise you and depending upon the age of the watch may replace.
2nd beyond that usually only independant jewelers will work with fossils, almost all chains will not allow their employees to even change batteries in a Fossil (they are easy to break).
2answers
Watch doesnt work even with a new battery
The 2 most common reasons for a watch to not work after a battery change are:
1) The circuit is not functioning properly.  99% of the time it is not efficient to have this fixed.  It almost always needs to be replaced when this is the problem.
2) The oils in the watch have either become thick like car oil, or thin and now the metal parts are causing too much friction.
The 2nd problem can be fixed by having the watch serviced.  Servicing is usually between $50 and $100 for Fossil's depending on where you go.  This may not be efficient since most Fossil's are less than $150.
Stores that service watches are Tourneau and Precision Time: www.tourneau.com www.precisiontimeco.com
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
