I have the same problem as described below: Ds is dead!! When i plug in ds to recharge, red light comes on for a second when inserting charger but then light goes off! Wont charge!
The DS's battery has a limit to how many times you charge it,but then again the charger's wire inside it might be disconnected.
Try to buy a new DS charger and see if its the wire,if its not then try to call nintendo to see if they might be able to replace the battery(for a fee).
You have a loose fuse on your circuit board, or your charger port needs to be replaced. I will fix it for you. $30 for the work and I will pay the return shipping, Thanks, [email protected]
Really sounds like a dead battery. The DS will not work if the battery is bad even when it's plugged in. You get the quick flash of the power light and that's it.
When you first get the DS it will have a bit if charge on it but only a few hours worth. When the DS charges it usally comes up with a orange/red ish light then that goes out about a few hours later when its charged. ad if you want to chek if it is charging correcly turn the DS on whilst it is charging and the little battery simble in the top right corner should show the battery carging.
