On my Whirlpool Thin Twin the water temperature selection knob is broken off. I think to replace it the front control panel must be removed. To remove the front control panel, the washing machine cycle selector/start/off knob must be removed. The Dryer knobs simply pull off. However, the washer cycle selection/start-stop knob doesn't seem to be a pull of knob. How can I remove this large knob so the panel can be removed and I can replace the water temperature selector mechanism, the shaft of which is broken off?
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
There
can be many reasons why your dryer will not start or turn...
The
most common causes are the belt breaking or jumping off, or the motor
going bad...
Here are a couple of tips that I wrote will help
you to figure out why your dryer will not run...
Dryer Repair
- The Dryer
is not Turning
Dryer
Repair - The dryer
will not start
heatman101
The Dryer knob for my Whirlpool Heavy duty came out. When I put it back in, it doesn't work
