ProForm 380i Treadmill: How to repair frayed edge of Walking Belt
On my ProForm 380 i Treadmill that I just bought used, the Walking Belt has been used while crooked, and so the belt is worn on the one side where it has run up against the edge and the metal guides. Also, the Walking Belt has stretched out along the edge, so it has "ripples" on the edge. I knew this before I bought it, as the seller lady disclosed the problem, so I got a good price deal on it, and being very practical person, I just want to repair it.
I am going to fix the alignment of the Walking Belt as Robert Braun suggested (above) by turning the hex screws in opposite directions.
But: Can I repair the slightly worn edge of the Walking Belt, maybe by putting a thin 1" wide strip of DUCT TAPE on the top surface, to prevent it from fraying any more? Or is there some other way to safely secure the edge of the Walking Belt?
Re: ProForm 380i Treadmill: How to repair frayed edge of...
Discription: WALKING BELT W/FASTENERS, Part # 193575, Model # PCTL49820, Price $48.83 In humble opinion you should replace the part, it sounds like an accident waiting to happen Call Icon Fitness @ 800-999-3756 and give them the info above.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. (5 to 7 cm) off
the walking platform. Be careful to keep the walking belt centered. Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
There are hex bolts on the bottom rear of both sides of your treadmill. Turn one side one direction and the other sides the other direction until the belt tracks in the middle of the platform.
If the walking belt is off-center, first remove the key and UNPLUG THE POWER CORD. If the walking belt has shifted to the left, use the allen wrench to turn the left rear roller bolt clockwise 1/2 of a turn; if the walking belt has shifted to the right, turn the bolt counterclockwise 1/2 of a turn. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Using the hex key, turn both rear roller bolts clockwise,
walking belt 2 to 3 inches above the walking platform.
the walking belt is properly tightened. Now if this does not solve this problem then check the drive belt and adjust accordingly, also reverse the process of the above mentioned
Unplug unit then, using the hex key, turn both idler roller bolts clockwise,
properly tightened.
PROBLEM: The walking belt is off-center or slips when walked on
SOLUTION: a. If the walking belt has shifted to the left, first remove
Using the hex key, turn the left idler roller bolt clockwise
walking belt. If the walking belt has shifted to the
right, turn the left idler roller bolt counterclockwise 1/2
of a turn. Then, plug in the power cord, insert the key,
Check both belts to be sure they are adjusted and not slipping.Check the underside of the walk belt to see if it feels frayed in the center as compared to the edges, the center always wears more than the edges a really worn belt must be replaced. if it is nor worn there is a wax lubricant for proform treadmills that can be purchased at retail stores that sell treadmills.Sears, dicks sporting goods and also treadmilldoctor.com are good places to buy it.
