first check for all the drivers in the device manager....
if every thing is perfect in driver side, then check if the ethernet/ lan is enabled....
then check is the light in the ethernet adapter is lit, when you plug any ethenet cable in it...
still if it is not working, then finally try to update the latest driver for the ethernet controller....
if nothing works, then buy an pci ethernet card and use it.....
you can also buy external cards like usb to ethernet converter...
even belkin manufactures usb to ethernet controller....
It sounds like the LAN card may be going bad. You can see if manually setting the IP address in the settings of the LAN card will work. If that works, then the card's routine for negotiating IP address assignment is corrupted. You maybe able to get some more useful life out of it by doing this until you can replace the LAN card itself. If you need more instructions on how to set the IP address manually, reply back and I'll try to step you through it.
Either the LAN card is faulty or the LAN driver is not installed and/or not configured properly or the LAN cable is faulty.
Check Device Manager to see if the LAN driver is installed, working and enabled. If not then re-install the LAN card driver.
If the LAN driver won't install or detect the LAN card then it maybe faulty and needs to be replaced.
Try a different LAN cable.
Is all the LEDs on in the modem?
Try rebooting the modem (power it off for 30 secs and power it up again).
When you replace and install LAN card you need to install also the driver. Be sure that your onboard ethernet PCI card are disabled in BIOS. So that the new install LAN card are working.
Check in the Device manager to see if all the devices are enable and working.
The one with a yellow ? against that device requires a driver installation.
Is the LAN device OK?
How do you intend to setup your LAN, is it for Internet access or a home network?
I need more information on your problem, together with error messages.
You should have gotten the LAN card drivers with your motherboard cd ( insert your motherboard disc ) and see if you can install them from there.
If not find out what network card you have by using http://www.gtopala.com/siw-download.html and download the relevant driver(s) from the manufacturers website. If you need more help let me know.
do you have a pci network adapter intalled with the proper drivers ? did you plug in ethernet cable directly into current pci lan card it will be located on lower part of back of computer? this will eliminate the problems with the router just to see if pci lancard is working or not . if the lan card is working unplug cable and plug in router and then try with router plugged in u might need to reset the router in order for it to work with lan card . if ur using and onboard lan eg attached to the motherboard then you must go into computer bios and enable onboard lan and then the ethernet cable should work with no problem good luck i hope this helps you get up and going getback to me if there are future problems.
