Tip & How-To about Televison & Video
URC-R6 Remote Code Entry
AVEX URC R6 Universal Remote Control Entry
Follow these steps to program your URC R6 Universal Remote control:
  1. Turn on the component you want to program.
  2. On the AVEX R6, press the Component button that you want to program and the SELECT [SEL] button at the same time. Hold down both buttons for 2 seconds until the TV Component LED light turns on. This signals that you are in programming mode.
  3. Enter the three digit code for your component. If this is the correct three digit number, your device will turn off.
  4. Press the component button you just programmed (in this case TV) one more time to save the code number. The component LED light will blink three times to confirm that the code was successfully stored.
I hope that helps.
____________________________________________________________________
URC-R6 Manual Download
Televison & Video Logo
2answers
I can't find the code to so I can program my
Here is an online manual. http://www.manualslib.com/manual/334599/Universal-Remote-Urc-R6.html
Procedures for programming zenith television
I can help you with your URC-3220 Universal Remote Control issues.
To program your One For All URC-3220 remote control to operate your TV you can use the direct code entry function.
To enter for a code for your TV follow these steps:
  1. Turn on your TV.
  2. On the remote, press the TV key once.
  3. Press and hold SET until the LED blinks twice, then release SET.
  4. Enter the first four-digit code from the code list. The LED will blink twice. If it does not blink twice, go back to step 2 and try the same code again.
  5. Aim the remote at the TV and press POWER. The device should turn off. If it does not turn off, repeat steps 2 through 5 with the next code in the list.
Review the complete instructions on entering the URC-3220 remote codes, please refer to my posted Fixya Tip One For All URC-3220 Code Entry.
I hope that helps.
One For All URC-3220 Manual
One For All URC-3220 Code List
One For All URC-3220 Code Search
One For All URC-3220 Reassign Key
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
