I needed to re-install Windows XP after a disk crash on a Compaq Evo. A number of drivers are not available after the installation, amongst them the Ethernet network driver (controller seems to be on the motherboard). Tried to download all 3 network drivers on the HP driver page. No success. Anybody any idea where I find that driver? Thanks! i cant finde driver for network controller
Need an ethernet driver update and audio update
Do a google search for the following:
Intel Pro2KXP.exe
This will give you the drivers for your ethernet card.
Worked for me
Bob Pro
What model is your Evo? D300, D300s, D300v, 310, 500, 510, 520?
Compaq Evo d51s/p4 1.8 ethernet network drivers xp
Change the speed of your card to 10 / full duplex.
and not to auto or 100.
I had the same problem... and with that change i am ok...
Which model EVO do you have?
Click here to select it.
Then in the left column click on Software and Driver Downloads.
Please vote if you find this information useful.
Thank You
SOURCE: Ethernet Drivers for Compaq Evo for XP
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=998
This should work.
And just to add that your system specs are really old and you should think about upgrading. 128 mb ram upgradable to 2 gigs.
Integrated 4x agp graphics...you should be able to install a new agp graphics card.
Or you should buy a new computer if you dont know how to build your own which can be tricky and expensive if you cant reuse many parts.
you can contact me i have an evo too. with all the drivers.
you have to make sure you have the intel 10/100 VE drivers.
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
PROBELM INSTALLING DRIVER - ETHERNET CONTROLLER
TRIED ALL 3 ON HP WEBSITE TO NO AVAIL
cant find ethernet controller
for evo netwark cpu
Compaq Evo 310
after installation I can have network and sound driver for my PC Evo d510 cmt
switched hard drive from a pc w/ xp to a pc w/ a motherboard that is older that had win 2000
p4/256/compaq
since you don't know which model it is, do the following:
Start button->Run
type: cmd
when you get the DOS box, type the following:
systeminfo
press return
Scroll all the way back up and look for "System Model" I believe. That will tell us what model you have and I can point you to the right place.
