20 Most Recent Compaq Evo D510 PC Desktop Questions & Answers
Where to find a windows xp master disc download for free?
search on google "windows xp free download you can also search on torrent site torrentz.eu or search on 4shared.com sites
5/12/2014 7:14:59 AM • Compaq Evo D510... • Answered on May 12, 2014
Where is the RAM placed on a D500 Compaq motherboard,and where is bios...I do not want to be cheated by money-hungry technicians.
Dear bro Wedei...first..i wanna to ask,did u know what does the RAM look likes?
11/28/2013 4:52:46 PM • Compaq Evo D510... • Answered on Nov 28, 2013
BCM5701 Ethernet
You need drivers for your Broadcom 5701 network interface card, and drivers for the others too. Go to HP website and look up that model. All the drivers should be there.
6/13/2013 2:44:03 AM • Compaq Evo D510... • Answered on Jun 13, 2013
BTV from wiztec.222. Password
a guess try with ADMINSHORT FOR ADMINISTRATOR
6/7/2013 9:33:30 PM • Compaq Evo D510... • Answered on Jun 07, 2013
Download drivers install
5/4/2013 6:23:21 PM • Compaq Evo D510... • Answered on May 04, 2013
How to install riser card compaq evo
Finding a compatible graphics cards may be a daunting task if you know little about your computer's components and technical specifications. To find a video card that is compatible with your system, you'll need to uncover information about your motherboard and power supply by opening your case and peeking inside. From there, you can perform additional research and make an informed determination of the types of graphics cards compatible with your computer. If your warranty is still in place, consult your computer manufacturer or builder to obtain the information you need Physically open your case and examine the number and types of slots on your motherboard. Unplug any cables connected to your computer prior to removing the side panel, but make a note of where your monitor connects. Remove your case's left side panel (when facing the front of the case). You may need to remove screws or to adjust latches. Please see your case or computer manual if you are unsure how to remove the side panel. Locate the current graphics card. By matching the port your monitor plugs into with the graphics card, you should be able to easily locate your video card. If you have an on-board graphics chip, the monitor will not connect with a card but with ports directly on the motherboard. Measure your case interior and the card slot. Make a note of how long the current card is. You must also measure for prospective maximum expansion card length. For example, if you measure 7.5 inches from the slot cover to the nearest obstruction (obstructions may include other slots, chips, or the processor), you will not be able to buy a card that measures 8.5 inches in length. The card you install must not affect any other components on the motherboard. Write down any brand name or model number so that you can verify the measurements by researching the card's specifications. Locate a serial number, brand name or product number for your motherboard and write it down so that you can research the motherboard and its specifications. Locate your power supply. Generally, the power supply will be in the upper-left corner of the case. Power cables connected to your drives, your motherboard and possibly your video card will run to the power cable. Make a note of the wattage, the brand name, and any model number. Perform research to verify the power supply's specs. Replace the side panel, and plug in all cables. Find a graphics card that will work with your motherboard and power supply and fit the motherboard's measurements. The card should both fit into the slot physically and be designed for the type of slot on your computer. Ensure that the card has drivers for your operating system. Hope this helps.http://www.4allmemory.com/video-card/compaq-hp-evo-d510-series/
1/1/2013 6:11:29 AM • Compaq Evo D510... • Answered on Jan 01, 2013
I have a compaq evo d510 problem with its drivers not found
click start control panel administration tools computer management device manager scroll through all of your devices
or for windows 7 click start right click on computer select properties in the left pane device manager scroll through all of your devices
if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver software
if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
or you might have to download them
rather doing a driver hunt which can take hours
http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html
Windows XP/Vista/7/8
it might take some time being a freeware driver solution
note: it will find all of your outdated drivers
this is a free driver solutions
this will automatically search for and find the correct driver
you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point click no to both of these then continue updating each driver free then restart once all of the drivers have been updated
also at cnet
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
IE: motherboard name sound drivers
you might have to try a few times to get it right
http://download.cnet.com/drivermax/3000-18513_4-10572602.html
Windows 2000/XP/Vista/7/8 free driver program
http://download.cnet.com/drivers-for-free/3000-18512_4-75548155.html
Windows XP/2003/Vista/Server 2008/7/8 free drivers
http://www.downloadcollection.com/device_doctor.htm
Device Doctor is a freeware Windows application that scans your computer hardware and checks to see if there are new driver updates available for your devices. It also locates drivers for Unidentified Devices in the Windows Device Manager. This tool was designed to be very simple and easy to use
http://www.innovative-sol.com/drivermax/
free program, paid update available
hope this helps
11/14/2012 2:33:00 PM • Compaq Evo D510... • Answered on Nov 14, 2012
I can't restore windows startup.
Remove unnecessary USB attached devices and media in CD.
11/12/2012 4:39:07 AM • Compaq Evo D510... • Answered on Nov 12, 2012
3answers
Free to air scrambled
etv codes
9/3/2012 2:37:25 PM • Compaq Evo D510... • Answered on Sep 03, 2012
2answers
How can i stop the fan from a compaq evo d510
WHY would you want to do that? It is neccessary for the fan to cool the CPU and other parts otherwise it dosent take much for them to overheat.. If you want to disconnect the fan.. plan on purchasing a new motherboard and CPU
2/22/2012 10:38:38 PM • Compaq Evo D510... • Answered on Feb 22, 2012
Compaq Evo Problem!!
hithis probleme causing by graphic card put the new one and try
2/19/2012 12:06:11 PM • Compaq Evo D510... • Answered on Feb 19, 2012
Cant display anythng on th screen
make sure the monitor is connected to the cpu and it is on just remove all the drive connection and remove RAM and check it give the beeps if it gives the beep that means board is ok but something is wrong with motherboard try to swap you power supply also and check the power connector like 4 pin connector is also connected .try with resetting the bios also.
Have a nice day and do not forget to rate please...!
2/3/2012 9:29:51 AM • Compaq Evo D510... • Answered on Feb 03, 2012
Compaq Evo D510 PC Desktop Logo
88 questions posted
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
evo Compaq
  • evo Compaq
Most Popular Question
39 t restore windows startup asking
  • Computers & Internet
