Homelite 'Yard Broom' Leaf Blower Logo
A
Anonymous Posted on Nov 09, 2017
I just bought a used bx-90 bandit and it runs great. The problem is that fuel oozes up thruthe top of the fuel tank right where the fuel line goes in. It runs down the side of the tank and all over everything. What is causing this?should I replace fuel and primer lines or does this mean the whole tank is bad? Please advise. thanks.
roeb
Level 3:
  • Homelite Master 819 Answers
  • Posted on Nov 21, 2017
roeb
Homelite Master
Level 3:
Answers
819
Questions
0
Helped
385262
Points
2343
Just replace the fuel lines they become hard and shrink allowing leakage. If your tank is like upper the part number is HM-0745499 or like lower part number HM-UP03825 or you can take to local small engine dealer and he will probably change cheaper than you can buy.
I just bought a used bx-90 bandit and it runs - bx90%20ut-08042-1-wv1yptaxhkluk1vufm5mq0o3-4-0.png
1 Related Answer
Anonymous
  • 130 Answers
  • Posted on Feb 12, 2011
SOURCE: Homelite bandit bx 90,
On the bandit, you are safe with a 40:1 ratio. In other words 8oz. of oil to 2.5 gallons of fuel.
1helpful
Craftsman 33cc weedwacker rep lace fuel lines
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, hh
2helpful
Fuel line diagram for sears mini cultivator
hello sir,routing fuel line for craftsman,homelite,ryobi,hedge and line trimmers,fuel tank under engine, looking at machine from rear, shall fuel line on left with filter attached goes to bottom port of carb, fuel line from right side coming out of tank with inside tip attached goes to bottom port of primmer bulb,top line on primmer bulb goes to top port of carb, fuel tank under engine,fuel line routing,looking at machine from left side, left fuel line coming out of tank(drain back only) goes to right side small port of primmer bulb, left side larger fuel line from primmer bulb to top port of carb, fuel line coming out of tank (larger line) on the right side with filter attached goes to bottom port of carb, when replacing fuel line it is very important to use the same ID and OD line the homelite takes a special line that is black in color and a bigger size,the bigger line is ID .08-OD140 small line ID3/32 X 3/16.when the lines dissolve small pieces will get in the carb clogging small passages and screen,it is advisable that you clean out carb,and use a new filter.hope this helps,any comments welcome,thank you. if the filter has broken off of the line half way that is where you will run out of fuel, ``
3helpful
Internal line in gas tank came loose
I need the fuel line routing diagram for a Craftsman Model No. 358.791510 Weedwacker 32cc/1.9 cu.in. 2-cycle
Jan 18, 2012 • Garden
Fuel line routing for craftsman chainsaw 358.350370
Jan 11, 2012 • Garden
Craftman trimmers has two gas lines wich one goes to the primmer the one with the filter or the thine one
Jan 09, 2012 • Garden
4helpful
Homelite bandit bx 90, What is the fuel mixture?? Thanks
1helpful
Ive bought a bike (1998 suzuki bandit thats been standing for a few years starts great but needs a good service whats the best way to go about this) im thinking of emptying it of all fluids (petrol and oil...
run some seafoam through the tank to clean up a little of the crud thats bound to be in the lines and carbs, check all the fuel and brake lines, flush the brake fluid both front and rear, change the oil filter, air filter, and spark plugs. get a shop manual and go from there.
1helpful
I recently bought a suzuki bandit 400 for the mpg. The fuel tank was off and i can't seem to find where the lines go from the valve under the tank.
One hose will go to a vacuum source and the other to the fuel tap. The idea is that fuel will not run until the diaphram in the back of the Petcock is pulled back by vacuum. Prime the engine first and then swap over when the engine fires up.
18helpful
Putting fuel line on right on ryobi 725r 15'' 31cc weedeater
Typical fuel line routing is:
One line (the one with the fuel filter in the end of it) comes out of the fuel tank2.gif and goes to the bottom fitting on the carburator. The second line comes out of the tank and goes to the bottom fitting on the primer bulb. The third section of line goes from the top fitting on primer bulb to top fitting on the carburator. Hope this helped and best wishes.
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
