Comfort-Aire BHD-501 Dehumidifier Logo
Anonymous Posted on Jul 04, 2010
Comfort Air Dehumidifier BHD-501-1
I have a Comfort Aie Dehumidifier BHD-501-A (purchased 08//2006)
and it is now leaking oil for somewhere on the bottom of the unit?
I when to empty it and I could smell oil....and It is ruining
my floor tile. I just discovered it when I when to empty it (07/03/2010)? It is supposed to be a sealed system unit. Where is the oil
coming from it is is sealed.??
Would it be covered under the 5 year due to a unit failure and or a defective unit.?
What would cause the oil too just start leaking for who knows where.
Where do I report this problem? Do I call Ace Hardware where it bought it...or do I call the manufactor? I have all my receipts of purchase.
I would appreciate any input or suggestions you may have.!!!!
Thanks Jolena219
Anonymous
Level 3:
  • Master 1,543 Answers
  • Posted on Jul 04, 2010
Anonymous
Master
Level 3:
Answers
1543
Questions
Helped
751658
Points
5690
Yes, you have a sealed system leak. Call the number in the book. I beleive that unit is manufactured by LG. You will need to have the unit diagnosed at an authorized LG repair provider. If the unit is under warranty, it will then be replaced by LG no charge, including the diagnostic. Make sure to bring in copies of the proof of purchase. The replacement unit will be shipped directly to you, and you will need to return your old unit, but shipping will be covered by LG with a pre-paid shipping label.
Testimonial: "Thanks so much for responding so quickly..I will follow your advise."
Do you put water in a dehumidifier
No, a dehumidifier takes water out of the air where it's placed. If it's very humid in the air, you should have a tank full of water after a few hours.
BHD-651D purchased 9-9-08 Ice builds up on coils. Filter and coils/fins clean. Air temp 72 F
What is your humidistat set at? Could you be trying to get to too low a humidity? Try to determine what the humidity is and set the stat just below that. In that way, once it reaches the setpoint, it will cycle off, allowing the coils to warm up.
If that works, lower the setting a bit more & see results.
Write back.
Gary
My dehumidifier model bhd-501 won't shut off& is very hot. What might be the problem? Thanks
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Dehumidifier is on but nothing happens
air filter clean.
water level switch problem.
control card problem
start at these points first........
if fan is working may be compressor.
Not accumulating water and condensation on top
Your unit is low on freon from a sealed system leak. The sealed system should have a 5 year warranty. You need an authorized LG tech to write it up for an exchange. Check your manual and call an LG service dealer.
Motor
Your problem may be the thermistor that causes the CH01 trouble code.
Top Comfort-Aire Dehumidifiers Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
