Vehicle Parts & Accessories Logo
Posted on Jul 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Rover 214. I have just changed the battery and
Rover 214. I have just changed the battery in my key fob and now my fob will not work.
blustu
Level 2:
  • Expert 279 Answers
  • Posted on Dec 21, 2011
blustu
Expert
Level 2:
Answers
279
Questions
Helped
175014
Points
437
Anonymous
Level 1:
New Friend:
  • Contributor 11 Answers
  • Posted on Jul 26, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
11
Questions
0
Helped
7075
Points
10
HAVE TO REPROGRAM REMOTES.... NEED MORE INFO
Does the key fob for 2009 Land Rover have a battery?
Yes it has a battery, two possibilities a rechargeable one, or a 2032. if you have the full black plastic cased fob it is a rechargeable battery. (most likely version)
to replace that will require some deft soldering skills. may writes ups available on multiple Land rover message boards
Key fob will not open or lock doors on a rover 75
Three possibilities - either the fob has stopped working, the receiver or other on-car devices has stopped working or the system has developed amnesia and forgotten the code.
Using the spare fob might persuade it to work or if you haven't a spare you could try a new battery in the one you do have. A friend left his fob and keys on top of the microwave oven once and it wiped the code from the memory.
The owner or user can do little more than fit a new battery. Specialised equipment is needed and no little amount of experience to test the system, diagnose and rectify the faults.
The dealer or an auto locksmith would provide the answer.
Range rover p38 problems
I have the same problem sometimes
1 Check the condition of your battery, if old, it will not give full power required to communicate with the security system.
2 If you don't have the EKA of your RR, try this next time you get caught, put key in the drivers door look, press unlock button on key fob and at the same time turn to unlock, if all locks unlock then the engine should not be immobilized - Good luck
2answers
Changing key fob battery on a 2007 range rover sport
Should be a very small screw holding the fob together. I would find a Land Rover forum like this one and ask the question. Doing a search on the forum you will likely find an answer. And a lot of invaluable information even many dealers will not know.
http://landroverforums.com/forum/
Key fob for rover 600 series won't work after
You will need to have the dealer reprogram it.
My immobilliser is stuck,the central locking wont work when I press the button on the fob,I have to lock/unlock doors with key and when I put the key in the ignition to try and turn engine on the little...
Suggestions
1...Make sure the fob battery is working (Try removing and replacing it again to reset everything )...or try another new battery in it
2...If that fails, try disconnecting the Main Car Battery terminal for 10 minutes, then replace it. This often resets everything as well.
Make sure you have the code for the radio before doing that
Key fob wont open range rover p 38 after batterys been disconected
need to re-sychronise the key put key in door lock hold button in on fob and turn then back to middle and let button go if it worked the hazard lights will flash. if you got a handbook it will explain it better
2helpful
Car key fob not working and locking car
i have a rover 25 and the key fob is not opening the car i could use the key to open it but the alarm will go off and cant stop it without the fob...
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
john h
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
