Rolex Submariner 16618 Wristwatch Logo
Posted on Jul 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It just stops and I have to tap it a few times to get it going again
Anonymous
Level 3:
Genius:
  • Master 1,970 Answers
  • Posted on Jul 03, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1970
Questions
0
Helped
847675
Points
4702
Mcdevito75 here, Have the basic serviceing done on your Rolex, use the repair service directory here at fixya, bottom of the page click on repair service thewn watches, or look for a small watch repair shop in your area to service your Rolex.
My michele watch keeps time for a few hours then stops. I have a brand new battery in it.
Hey, I am having the same issue. After a few hours, time stops but if i pull out the crown and push back in, I'm back in business, but after a few hours same thing. Make since the stop watch is on and i am having the worst time figuring out how to turn it off. The chronograph instructions for the Deco are not easy to understand.
My automatic watch stops! plz help
Go to repair shop mb.
Apr 24, 2017 • Watches
Skmei 0817 black digital watch-user manual
WATCH KEYS: Top RIGHT=S1 Bottom RIGHT=S2 Bottom LEFT=S3 Top LEFT=S4
SKMEI WATCH User Manual Model 0817
Operating instructions:
In normal mode modelDisplay: Week-Minutes-SecondsPress S1 show Month and DatePress S2 button to show Alarm Hours and MinutesModes Covert: Press S3Modes of watch:
In normal display mode: Press S3> chronograph mode (stop watch)>time setting mode>>>(then back to beginning)
Chronograph function:
In normal display mode: Tap S3>enter chronograph mode>
tap S1 to start>
tap S2 to lap time>tap S2 read time>tap S1 to stop>tap S3 to exit tap S1 to stop
tap S2 to reset>tap S1 to start ...then begin againChime of every hour ON/OFF:
In normal mode hold S2 and then tap S3, if all icon of week on means Chime ON, otherwise means off.Alarm Setting:
In normal time Mode, tap S3 twice enter into Alarm setting mode, and the Hours flashing Tap S1 to adjust correct hour of your alarm. Pay attention to AM/PM (Military 24 hour display)Tap S2 the Minutes will flash. Tap S1 to adjust correct minute of your alarmTap S3 to save/exitTime & Date Setting:
In normal time Mode, tap S3 three times to enter Time & Date setting mode and Seconds flashing.Tap S2 and the Minutes will flash. Tap S1 to adjust minutes ("H" is 24 hour format)Tap S2 and the Hours will flash. Tap S1 to adjust the correct hoursTap S2 and the Date will flash. Tap S1 to adjust the correct monthTap S2 and the Weekdays will flash. Tap S1 to adjust the correct days (M=Monday, T=Tuesday...)Tap S3 to save/exit.Back-light setting:
Hold S4 will show all kinds of colors (blue, green, red, cyan, purple, yellow, orange) Just stop hold the button, last color lit will be memorized to set as current back light. 9b7a554e-43c1-4abb-a52d-3caf02dd616f.jpg
Jan 14, 2012 • Watches
My watch only works half the time it will go and then all of a sudden stop. and if I tap it it starts going again
Watches are little machines, they do require maintenance at some stage. You haven't said what type of watch, quartz, mechanical, digital?
How old is it?
The oils inside watches are really good, but will still go off over a 7-8 year period. I'd say you may need a clean?
Of course, if it is a fairly new battery operated watch your problem may be as simple as a loose negative contact breaking contact with the circuit board.
Best to whip it into your local watch shop for a look.
Feb 14, 2011 • Watches
1helpful
Self winding does not work
Could be its just not a good quality watch, you didn't state the make. if its an invicta, then tbh, its to be expected they can be very hit and miss. You can buy demagnetizer for about $10, £6-7. Things like speakers, computer monitors or strong electrical field can magnetize a watch making them perform very inconsistently.
Time
Hold in the MODE button until the alarm time appears.
VERY IMPORTANT - Tap the MODE button again, and the time should appear with the seconds flashing.
Use StART/Stop to choose among seconds, hours, and minutes, and
Use ADJUST to increase the selected number
Press MODE to put the thing back in regular operational mode
67helpful
10answers
Timex 1440 sports WR50M
Solution #2 by Guest, posted on May 13, 2008 solved my problem. OUTSTANDING solution #2!
1. Hold in the MODE button until the alarm time appears.
2. VERY IMPORTANT - release and TAP the MODE button AGAIN, and the time should appear with the seconds flashing.
3. Use StART/Stop to choose among seconds, hours, and minutes, and
4. Use ADJUST to increase the selected number
5. Press MODE to put the thing back in regular operational mode.
After several attempts with other directions over the last four months, these 5 steps WORKED.
Top Rolex Watches Experts
NOEL
NOEL
john h
k24674
Are you a Rolex Watch Expert? Answer questions, earn points and help others
