SOURCE: Sound in left earbud shorts in and out
If its not hard to open the case, just solder the connection again (only if you found out that the problem is inside).
Also check the wire if it have 100% connection. You may also check skin of the wire. If found out no good, so possibly this could fix the problem.
SOURCE: Sony MDR-NC11 Left Earbud has no sound
They should come apart right where the metal meets the plastic, just below the buds themselves - be careful, one set like that I took apart were actually surface-mounted to the housing, there weren't any leads to repair...
SOURCE: left earbud problems
Well, I had the same problem with the right earbud. Luckily I was under warranty with Target, so they told me to contact Bose. I did and they had me send in the headphones (to make sure I waas telling the truth) and about 2 weeks later I got my earbuds back. Their customer service is excellent, so that's what I would reccomend
