Our time is off on our phones. I know this must be a simple process but there does not seem to be a manual... Do you have simple instructions or a manual I can down load?
Sorry, the tester012 was an accident, so I wanted to repost in case there were more questions on this.
The answer still stands for most Nortel PBXs:
To set the time and date of your system you program in load 2:
Step 1) LD 02
Step 2) STAD "Day Month Year Hour Minute Second"
i.e. STAD "24 11 1976 15 41 49" =
November 24th 1976 3:41pm 49 seconds"
To test it...
Type: "TTAD" - (this tests time and date)
But I also wanted to clarify that it is in the manual, but since there are multiple manuals with a Nortel PBX, that you need to look in the LD (or Loads) in them. This particular one is found in LD 02.
Another site to check out for a crash course in LD for Nortel (in case you have similar issues that you need assistance on) is this one here:
http://www.pbxinfo.com/meridian-systems/16288-meridian-crash-course-programming-guide.html
I hope this has been helpful, again I am sorry for not having logged in properly to be notified on more explanation when I posted Solution #1.
Step 1) LD 02
To test it...
If you are lucky your service engineer may have configured a key on your switch to allow you to do this;on the extreme right hand side there is a row of 10 keys.press each one of these keys one at a time and at the same time watch the screen.if you see the time appear in a 24 hour format ie 12 40 then this is the key you need to use to change the time.the process is as follows.
press a loop key (these are the keys you use to answer calls)
press the key you found from above
enter the time in a 24 hour format ( 15 35 ) 335 pm
press the key you found from above again
press release
wait a few minutes and time should change...i hope this helps
How do I correct the time on the display
How do we change the time on the phones for the daylight saving time change?
ON THE NORTEL MANUAL THERE IS NO FEATURE FOR CHANGING TIME AND DATE
PLEASE HELP
The time on my Nortel phone is incorrect. How do I fix it ?
