Tomtom GO 930 GPS Receiver Logo
Anonymous Posted on Jun 23, 2010
Unit will not connect to charger or charge.
The mini USB port on the bottom of the unit will no longer make a connection with any charger (car charger, wall charger, or computer base). The green light does not come on, the unit does not charge. I believe it is a loose connection somewhere inside the TomTom, but I don't know how to take it apart or address this problem. TomTom is no help, as if a unit is out of warranty, they will not repair it (even if you pay). Insane.
  • Anonymous Jun 23, 2010
    The first "expert" basically said, "Take your unit apart and look at it." Not that helpful, as I am not a technological wizard. When I asked for additional information, he told me that was my bag. I need a little more assistance than that. I will be eternally grateful. Thank you!
    PS. I have since figured out, thanks to another website, how to get it apart. But I still need more info on what exactly to look for inside. Thanks again!
    I have contacted TomTom; they will not touch a device if it's out of warranty, nor give you any help.
Wale Sarumi KomputerSolution
Level 3:
  • Tomtom Master 6,993 Answers
  • Posted on Jun 23, 2010
Tomtom Master
Level 3:
Answers
6993
Questions
Helped
1701380
Points
1261
its a good idea to dismantle the gps. You can check the link below as it directs you on how to dismantle your gps. Though the link is for Tom-Tom GO 910, but it the same dismantling procedure. The link also provides pictures that would be very helpful.
http://www.unc.edu/~bmoc/tomtom/Tomtom%20Go%20910%20Dismantling%20Manual.pdf
I wish you good luck.
ZJ Limited
Level 3:
  • Master 17,989 Answers
ZJ Limited
Master
Level 3:
Answers
17989
Questions
0
Helped
14459267
Points
60858
Sounds to me like you need a new charger port. I've never hear this happen with any GPS, but I have had it happen with a cell phone. I have also had my cigarette lighter "port" of my car stop working. Maybe a "home charger" would be something to try?
Also, your best bet is probably to call the company and they can tell you what they can do for you if you ask then how their repair policy works.
Tell us news.
FIKRET UNALIR
Level 1:
  • Contributor 239 Answers
FIKRET UNALIR
Contributor
Level 1:
Answers
239
Questions
0
Helped
65961
Points
5
You may repair it yourself.
1. Open the back cover.
2. Look carefully if there is a short cut that can be seen.
3. Check the cables and the colors of them attached to USB port.
4. Choose your usb kind from the below picture.
5. Cut the short cut or stick it if disconnected.
Unit will not connect to charger or charge. - 820089b.jpg"/uploads/images/820089Unit will not connect to charger or charge. - 8167929.jpg"820089b.jpg" class="h_mi" />
  • 2 more comments
    Okay, first things first... How do I take the back off? The unit does have two screws on the back (although they're not normal flat or Phillips screws - they're star shaped), but otherwise it appears to be all one piece.
  • FIKRET UNALIR
    FIKRET UNALIR Jun 23, 2010
    I have given you a general information about fixing the problem. You should find the details. It is up to you that how you will do it. This is only the critic information you will need. I want to see your feedback, after that I am going to try to help you a little more. If I have enough time then I will give you additional information of course. Thanks.
  • FIKRET UNALIR
    I have helped you enough. But you wanted me stay online and say what you will do step by step even you wanted me to say unscrew the first screw with your right hand while looking at the item from the left hand side and please stop now and.... What do you want me say and untill when? We must work together from the begining when I was a child and there was something....!?
    I only wanted you to give my right but you did not....Only took my time. Thank you.
    What you basically said was "Take it apart and look at it." Even a link showing HOW to take it apart would have been helpful. Please excuse me, but when I pay for "expert" advice, I actually expect the person to take the time to answer my questions, not get an attitude and tell me he will help me when and if he has the time to do so - the whole point of PAYING for your help was that you were supposed to WORK FOR ME. That means basic information such as, "You will need a special screwdriver called a torx screwdriver to remove the case. After you remove the screws, you will then need to insert the screwdriver into the hole and use that leverage to separate the screen from the back of the case." Not to mention the fact that even after I get it open, I have to unscrew another four screws to even get a glimpse of the USB port, and there are NO wires attached to it or anywhere near it. And how did I figure all this out? By looking at a free website. Even after getting it apart, your "expert" advice was STILL useless. So, hey! Thanks for nothing!
Pioneer Model: DEH-P8400BH, USB port goes inactive
It's possible that the head unit's USB port or the wireless phone charger is no longer functioning properly. You can try the following to troubleshoot the issue:
  1. Disconnect the wireless phone charger and test the USB port by connecting a different device. If the other device doesn't charge, the USB port may be faulty.
  2. If the USB port is working, try a different wireless phone charger. If it still doesn't work, the issue could be with the wireless phone charger.
  3. Check the car's fuse box for a blown fuse related to the head unit.
  4. If all else fails, contact Pioneer or a professional car audio installer for further assistance.
Why does my nuvi 1490 keep turning off?
My first question is: Is this happening when connected to an external power source such as a car charger/adapter? or is this while on battery power? If on battery power, then the battery is not fully charged or is weak and can not hold a full charge. There is another possibility too and that is that the battery is not receiving voltage from the charger because the rear mini-USB port is loose (a common problem on the Nuvi 11xx, 12xx, 13xx, 14xx & 25xx models). One more issue can be the firmware version. Older firmware was unstable and caused the unit to reboot. If you are getting constant pop-up messages that the unit is about to shut down, then this is a good indication of a USB port issue (loose or broken). When this happens, the battery can not be charged and the unit will turn off. More information can be found here: SHARCNET USA Out of Warranty GPS Digital Camera Repair
My sky caddie sg5 wont charge
If you follow these instructions which I think you know how to, it will recharge. If not the rechargeable battery needs to be replaced
To charge the battery, simply follow the steps below:
  1. Gently pull back the rubber cover to gain access to the mini-USB port located at the bottom of the SkyCaddie. Insert the mini-USB connector of the supplied wall charger into the mini-USB slot.
  2. Plug the wall charger into the AC wall outlet. While charging, the charging indicator in the upper left-hand side of the SkyCaddie will show red. The charging indicator will switch to green when fully charged. You may also notice the unit's screen turn on and off periodically.
The battery will charge, even with the SkyCaddie turned off. A full battery charge may take 4 hours. Once fully charged, expect 36 holes of continuous play.
Warning!Always connect the cable to the SkyCaddie first before connecting to AC power or PC USB.
Jul 16, 2011 • GPS
6helpful
2answers
My Nuvi 200 will not charge and the USB port
My condolences. I would suggest you plug the unit in to your computer's USB port using an appropriate data cable (in case you no longer have the Garmin data cable, there are lots of devices, including cameras, that use such a cable with the large USB plug at one end and the mini-USB at the other). That would give you a handle on where the fault lies -- in the auto charger cable itself vs the nuvi's socket. If the nuvi charges from your computer, you're halfway home; if not, I suspect the cost of repairing the nuvi's USB jack could exceed the cost of a replacement unit.
3helpful
I turn it on, logo comes on, and it turns off. I've tried holding the on button 8 sec, no luck.
With the limited information provided, a simple first step is to make sure the internal battery is either fully charged or is in a condition to accept a charge. When the internal battery's charge is allowed to below a certain level, it will no longer be capable of accepting a charge via the car charger.
The battery can be conditioned to accept a charge easily, however. This is done by connecting the GPS to the computer via USB port, NOT the car charger. Some Garmin GPS units come with a 120 volt charger that connects to the USB port of the GPS - this method is also an acceptable charge / condition method. Leave the GPS connected for 8 hours or longer (over night) and try to power up again.
I hope this helps!
3helpful
Low battery, won't charge
connect the garmin to your computer using the usb port. It will start charging then. For some reason when the battery goes dead in this unit the only way to charge it is with computer. the car adaptor will not work once the battery gets real low.
3helpful
2answers
Broken mini USB port on TomTom One
It can be done with difficulty. I change them on a regular basis though as i run a repair business.
If you want me to change it I can do it for a small fee.
[email protected]
7helpful
3answers
Magellan Maestro 4250 wont charge
No the device is not defective. magellan has this stupid usb interface problem preventing the unit from being charged and used at the same time, they do that so you have to use there charger. the unit will say usb connected and will not boot up like normal at all. unit will be locked up until the usb is unplugged. most usb devices charge at 5v with 500mA, and the magellan requires 5v 1A. Ipod Charger charges at the 1A with 5v but wont work
1helpful
2answers
Can I connect the wires from a car charger to the connections under the unit ?
An alternative is to use a navman P1 "hotshoe" This allows charging to be carried out through the bottom strip connector.
Available from Magicgadgetz at a cost of £20
Garmin nuvi 260w not operating while plugged in
Based on your description, you are doing it right. You said....
"when i connect it to the car charger it shows the computer sysmbol and starts charging. there is no other usb port on the device"
That is correct. It takes about 2-3 hours to fully charge a low battery.
There is only a mini USB port on a 260.
It's used for charging and downloading updates of software or maps.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
