Car stereo cd player are 12 volt you can connect polarity to battery line1 positive(+) and line 2 negative(-) need a fuse 2 ampere for line 1 protection for continue use and the speaker are left and right at the back or RCA jack red and white color or either.
here you go... 1998 Ford Windstar Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Green/Violet Car Radio Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black/Light Green Car Radio Illumination Wire: Green Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): White/Light Green Right Front Speaker Negative Wire (-): Dark Green/Orange Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Light Brown/White Left Rear Speaker Negative Wire (-): Light Brown/Yellow Right Rear Speaker Positive Wire (+): Light Brown/Green Right Rear Speaker Negative Wire (-): Brown/Pink
1998 Ford Escort ZX2 Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Blue/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: Green Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: White/Orange Car Stereo Amplifier Location: Under the driver seat. Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Violet Left Front Speaker Negative Wire (-): Blue/Orange Right Front Speaker Positive Wire (+): Blue/White Right Front Speaker Negative Wire (-): White Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): White/Blue Left Rear Speaker Negative Wire (-): Red/Blue Right Rear Speaker Positive Wire (+): White/Green Right Rear Speaker Negative Wire (-): Blue
Here are factory wire colors from modifiedlife.com:
1995 Ford Escort Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Blue/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Violet Left Front Speaker Negative Wire (-): Blue/Orange Right Front Speaker Positive Wire (+): Blue/White Right Front Speaker Negative Wire (-): White Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): White/Blue Left Rear Speaker Negative Wire (-): Red/Blue Right Rear Speaker Positive Wire (+): White/Green Right Rear Speaker Negative Wire (-): Blue
Here ya go, this should help ya out... Be sure to vote!!!!
2000 Ford Escort Car Audio Wiring Schematic
Car Radio Battery Constant 12v+ Wire: Blue/Red Car Radio Accessory Switched 12v+ Wire: Blue/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Red/Black Car Stereo Dimmer Wire: N/A Car Stereo Antenna Trigger Wire: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 5 1/4′ Car Audio Front Speakers Location: Doors Left Front Speaker Positive Wire (+): Purple Left Front Speaker Negative Wire (-): Blue/Orange Right Front Speaker Positive Wire (+): Blue/White Right Front Speaker Negative Wire (-): Dark White Car Audio Rear Speakers Size: 6′ x 8′ Car Audio Rear Speakers Location: Rear Deck Left Rear Speaker Positive Wire (+): White/Blue Left Rear Speaker Negative Wire (-): Red/Blue Right Rear Speaker Positive Wire (+): White/Green Right Rear Speaker Negative Wire (-): Blue
Go to halfords or somwher like that buy the iso connector for your make and model
if your car still has the ford plugs on the ends of the wires just plug in the connector between car and stereo If the ford plugs are missing cut the ford end off the connector match the wires to your car and solder together and plug into your stereo or any others you buy in the future with an ISO connection Did this with my 89 orion.
1994 Ford Escort Car Stereo Wiring Diagram
PLEASE RATE THIS INFO AS A FIXYA! IF YOU FIND IT IS WHAT YOU NEED, THANKS ALLOT. -->
