HTC Touch Cell Phone (Unlocked) - Soft Black Logo
Anonymous Posted on Jun 24, 2017
Touch screen working funny
Hi, Touch screen of my HTC not working properly. it does not click exactly where i touch. on phone list, if i touch 2nd phone number it clicks on 1st one. Same thing with keyboard. if i touch on 'L' it clicked 'P' and so on. it's very hectic to use phone in this situaltion. i have came across with this situation once before but it cure without doing anythign after a day.
Pl. help.
Thanks
Sharad kadam
9821208717
5 Related Answers
Anonymous
  • Posted on Feb 02, 2009
SOURCE: Touch pad is not working in HTC touch phone
I had a stubborn version of the dead touchscreen problem. Screen was dead this morning upon power-up and no combination of hard or soft resets made any difference. Removed screen protector (which had worked fine for a year) and cleaned out seam of screen too - still no change. Ten days past warranty expiration - figures!! Eventually I concluded there was nothing left to try but a ROM upgrade, even though I didn't expect that to help... IT DID!! I'm a Bell customer in Canada, so I downloaded the latest Bell ROM from here: http://www.htc.com/us/supportdownloadlist.aspx?p_id=70&act=sd&cat=all and did the install. Lo and behold - touchscreen working like new!!! My original version was factory 1.<xxxx> and newest was 3.<xxxx>. Fix cost me a day of surfing, but better than $400!!
Anonymous
  • Posted on Jul 18, 2009
SOURCE: touch on touch screen phone not working
Hi, I have the HTC touch from bell. I too had the same problem with my screen. It stopped working completely. The phone is pretty much useless without the touch screen working, there is only 3 buttons on the phone! Can't even dial 911... So I was pretty pissed when the screen stopped working. Like others I searched the internet for answers and didn't really find too much. I found that maybe tapping the four corners of the screen firmly might work, but it didn't. Taking the protective cover off the screen might work, didn't work. I tried updating the ROM, using the official software from HTC website. I was able to update my phone, but my touch screen still didn't work. Someone said something about some copper connections inside the phone, need to be re-adjusted behind the screen or something like that. So I willing opened the phone (only 4 hex screws on the back) and took the front plastic cover off. If you look closely, you'll see the front cover is plugged into the 'motherboard' and you can simply unplug it. I unplug it and plug it back in, do a restart of the phone (take battery out and back in) and still nothing, screen doesn't work.
I noticed that on the front cover of the phone (underneath) you can see the copper band of wires that connect to the buttons and probably feeds the information from the touch screen to the 'computer'. I accidentally unplugged the wire (thought I broke it) but was able to insert it back in. I put the the cover back on, put the battery in, power up phone, BINGO! Touch screen works! What I did to make it work? Not sure...
But for people with the same problem. Try this:
1) update ROM
http://www.htc.com/us/SupportDownload.aspx?p_id=70&cat=2&dl_id=98
2) Unplug and plug back in that little wire.
http://img81.imageshack.us/img81/1912/htctouchx.jpg
Its the red circle I'm talking about.
Anonymous
  • Posted on Apr 11, 2010
SOURCE: my touch screen on my htc touch HD is not working
how can i do that if my touch screen isn't working ...i can't start my phone...:( what can i do?
Anonymous
  • Posted on Aug 04, 2010
SOURCE: my htc cell phone touch screen does not work
my htc cell phone touch screen does not work all a sudden
Anonymous
  • Posted on Sep 01, 2010
SOURCE: HTC Touch - Screen & touch flo problem
i did all things described to get the screen workin,pressed the red n green buttons simultaneously n with the friggin stylus i pressed the reset button underneath, pulled the battery out a coupla million timesn put it in, but it jus doesnt unlock, the touchscreen aint workin, i can call, mssag or do anything except recieve calls, Arpan
My htc in danish .. i need it in english ??
Hi there!
Changing the language of your HTC touch is really easy. Just follow this simple steps:
  1. Turn on your HTC Touch. Touch "Start" on your Home screen. Touch "Settings.
  2. Touch System > Regional Settings. Select the proper region for the language you desire. Touch "OK" when prompted and "Exit."
  3. Confirm your selection has taken effect by checking the language of any menu item from the Start screen. Your selections should be in the language you chose
If you need more information about your HTC Touch, just open this website: HTC Touch User Manual.
Hope this helps.
1helpful
Ihave a touch diamond 2 and the touch screen wont function properly. I touch it on one spot and it clicks somewhere else on the screen
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again.
in other to resolve the problem,you will need to replace the touch screen with a new one.
For touch screen replacement , Contact a technician.
Take car
1helpful
Email has fronzen on the screen and I can't unlock the phone
TOUCH SCREEN
the touch screen of the phone you are using is weak and it is not responding properly again. Phone is ok and working fine,just the touch pad problem.
Take care.
My HTC Touch's screen is not responding to anything i do other than button presses... Is there anyway i can recalibrate without hard reseting my phone
in ther to resolve the problem,you will need to replace the touch screen with a new one.
Take care.
1helpful
Top right of touch screen not working accurately when I touch on the foward arrow in calendar it goes backward e.g it is the 16th and i want to look a week ahead to the 23rd it goes to the 9th if i touch...
Take care.
10helpful
3answers
My touch screen on my htc touch HD is not working properly...WHat Should I do?
1helpful
It gets stuck on the windows mobile screen
You have to execute a "hard reset". The exact method depends on the exact type of HTC phone you have. You should Google for "HTC Touch <your exact phone type> hard reset" and follow those instructions.
Looking at the picture you have a HTC Touch P3450, in which case you can instructions at: http://blog.ryjones.org/2008/01/14/htc-touch-hard-reset/
Make sure you follow the instructions properly. When it still doesn't boot up, you can always perform a firmware upgrade/reset, that's almost guaranteed to work, but is complicated and might break your warranty (depending on wether you bought the device yourself or got it as part of a package deal from your provider).
Htc touch screen is not working
Can you see any cracks in the touch screen?
You can have it replaced without replacing the whole screen which is quite expensive
Top HTC Cell Phones Experts
NOEL
NOEL
john h
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
