Hi if you give me your imei number off the back of the phone under the battery then i can get you the master reset code for your phone, how ever this code wont work if you have entered the wrong code more than 5 times if you have then you need to take your phone to a phone shop and get it reset.
if you have not entered the wrong code more than 5 times then the master code will reset and remove the security code unless you want to put a new code back on the phone, the imei number is located under the battery if your unsure which one is the imei then tell me all the numbers then i can get the imie number and then use some software to give you the master code.
The imei number will tell me if the phone has been reported stolen or not and if it does come back as stolen i wont be able to provide you with the unlock code ok
let me know then i can assist you further and tell you your 10digit master code
