Check if bulb is busted if not check pedal brake switch, sometimes socket connectors were detached or loose or use light tester to check manually from the fuse connection down to the wiring circuit until you reach the tail of your car. let somebody do the brake pedal pushing when checking using the light tester. i don't see any reason if your problem is not solve using these technique
