Check that the tube feeding the air pressure switch is not bloked by unpluging from where the tube joins the with the switch and **** the tube hard. DO NOT SWALLOW.
Then put back and try again.
if doese not work please give more clarificaton on what hapens
If it has a timer, then when the power was on again, it probably reset to auto, you need to reset it to manual cooking
Refer to your instruction book if you have one.
Otherwise it is a question of pressing 2 or more buttons at the same time on the timer to reset it to manual
Check your main panel. If you ran it for a long time with the door open, the elements never reached their shutoff temperature. Quite possibly, you burned them out.
On our oven, we have to reset the clock before the oven will work. I think it's because of the automatic timer features.
Yours is a slightly different model, but on ours we have to press the two buttons with arrows on, at the same time as turning the clock dial. Once this is done, the oven should work again.
EUREKA! I found the reset button and my oven is heating as we speak. Ok, open the oven door. there is a thin panel with vents right at the door latch. Unscrew the (6) screws and pull off the panel. There is a red button on the left back behind the wiring. GOOD LUCK!
On my Dacor oven whenever I use the self cleaning feature it trips the breaker and the oven doesn't heat up. It can be reset, but you need to take off the front panel and reach way back for the red reset button.
I also have a Dacor Model PCS130. This solution worked AND saved me from spending $50-$105 for a service technician to come out just to look at the problem.
The high temperature sensor tripped when I kept the door open part way while broiling (never listen to friends who don't have the same oven as yours). Afterwards, I couldn't get the oven to go above the prebake temperature of 135°F using any of the settings (bake, broil, convection bake, etc...).
I called Dacor customer service and they told me about the high temperature sensor but wouldn't say how to reset it. They suggested I call a third party technical service company and gave me their numbers. But, I'm glad I found this site...
All you have to do is open the oven door and you'll see the grille/grate/steel cover plate where the door latch sticks out of. If you look inside, you can see the electronics that operate the door latch as well as the temperature sensor unit a little farther back. You can even see the RED reset button. But, it's a little too far back for you to press it without removing the cover plate.
6 screws is what holds my cover plate in place. Once that's off, you can reach in and press the RED reset button (I pressed it twice just to make sure) and you'll hear it click. Screw the cover plate back in place. Close the oven door and test it out.
It took my oven about 5 minutes to heat up past 135°F so I was unsure if the problem was fixed or not during that time. But, once the oven heated up sufficiently, the temperature began climbing fairly quickly and I was able to breath a sigh of relief. It works!
This is such an easy fix, I don't know why Dacor customer support doesn't just tell us how to do it ourselves instead of paying for a service tech to come out and do the same thing. Even better, maybe they should make the reset button more easily accessible (like on the control panel) if they're concerned about people getting in and messing up the other electrical connections when trying to reset the high temperature switch. Computers are far more technically advanced than your oven and THEY have reset/reboot buttons right in front.
