startingwith the power off push and hold the call button while the head set turns on....then continue holding the call button until the light turns blue that has enabled the pairing mode now the pin code for all h300 model bluetooth device is 0000..i hope this helps
I have a Blackberry curve and i use this headset. You just hold in the key to your bluetooth till it stays solid blue light, then go on your blackberry under "options" then "bluetooth" then search or add new device. it will search it, pascode is "0000" should load up then. then everytime u put ur bluetooth on and hit the button to turn it on ur blackberry will pop up and ask if you want to use it, just hit yes and your good to go.
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit. (The light will flash while you
hold the Call button.)
If the indicator light is flashing or does not
remain steadily lit, turn off the headset and
repeat step 1.
Before you can use your headset, you must
pair (link) it with your phone.
Step A - PUT HEADSET IN PAIRING MODE
Note: To turn off headset, see "Turning On and Off" on the
reverse side of this guide.
PAIR
Your Phone
Select (Menu) > Settings > Connection >
Bluetooth Link > Handsfree > Look for Devices.
The phone lists all Bluetooth devices it finds.
Select Motorola H300.
Press OK or Yes to pair (link) the handsfree
device.
Enter the passkey 0000 and press OK.
Note: Passkey cannot be changed
from 0000.
The quick answer is that you can put it into pairing mode, and your
phone should recognize it. To put into pairing mode, push and hold the
large power/answer button for at least 6 seconds. The light will start
flashing, indicating that it is in pairing mode. Go into the Bluetooth
menu on your phone and make sure Bluetooth is turned on, that your
phone is visible, and that you can search for new headset devices. Make
sure the headset is still flashing. When you discover the headset in
the phone, it may prompt you for the code. I believe the pairing code
is "0000". Add the device to the phone. You should now be able to use it with your phone.
If this doesn't get you there, do a search for H350 Manual to get a pdf of the user manual and quickStart guide.
