Video Cameras Logo
Posted on Apr 04, 2017
Interface cable to connect one side DV the other USB
I have Sony DCRTRV410E DV I have Sony DCRTRV410E DV to USB connect cable problem:I need to have an interface DV->USB in order to connect the video output to my Laptop for transferring video to Laptop. I meed an interface cable for DV out camcorderside and USB in to Lapton side. Please tell me WHERE and HOW to get this More I have Sony DCRTRV410E DV to USB connect cable problem:I need to have an interface DV->USB in order to connect the video output to my Laptop for transferring video to Laptop. I meed an interface cable for DV out camcorderside and USB in to Lapton side. Please tell me WHERE and HOW to get this type of interface cable
2helpful
I want to download material from my Sony DCR-TRV17E MiniDV camcorder to my Windows 7 laptop. Can you help with connectivity issues please?
This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 cameras have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. My camera came with the correct lead.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
Windows 7 compatibility- Sony say it is compatible, but "Windows 7 needs to be preinstalled at the factory" (meaning installed on the computer) rather than an Update to Vista or XP performed by the user. You must also use i.Link, not USB.
Usb invalid on the DCR-HC26 when i plug it in to a mac or pc
This type of camera downloads video with a Firewire (Sony call this i.Link) connection. Some mini-DV and D8 have a USB connection which is used for stills ONLY.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. As you have a MAC, you may already have a port.
There is a Sony tutorial page for downloading video to computer at THIS LINK You will need to select Windows as the operating system, then Digital8 as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many cameras, and you are strongly recommended to use i.Link (which everyone else calls Firewire).
3helpful
I am trying to connect my Sony DCR-TRV10E to my home computer via ilink-USB cable, but my computer does not recognize the Camcorder.... I guess this is due to missing drivers for Windows 7. Can anyone help...
USB and i.Link cables are not the same thing. What Sony call i.Link everyone else calls Firewire, DV or IEEE1394, and it is a different standard from USB with different connectors.
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. If you are trying to use a USB cable for video download, then it won't work for this camera. The driver is not the problem, this model is not on the Sony list of cameras that will download video over USB.
There is a Sony tutorial page for downloading at THIS LINK You will need to select Windows as the operating system, then Mini-DV as the camera type, then select the type of connection. As you will see, the USB option warns that it won't work with many Mini-DV cameras.
1helpful
2answers
Hello, I connected my DCR-HC54 (minidv) to computer using USB cable (come with camcorder). latest PMB is installed on windows 7 64-bit home premium. It gives following message: Cannot find the Handycam...
This type of camera usually downloads better with a Firewire (DV) connection. Sony call this "i.Link". Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. According to a list on the Sony site, your particular model is not one that can use USB for video transfers to computer.
Sony have a help page for your camera, with tutorials and downloads, at THIS LINK
Dec 31, 2010 • Cameras
I cant transfer my videos from sony handycam dcrhc36 to my computer os window 7 evenafter downloading pmb from sony sitemy computer is not detecting the handycam
You don't say what type of connection you are trying to use. This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file. The way it works on my computer, the camera is controlled by the computer software through the Firewire cable. Confusingly, Sony call Firewire "i.Link".
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card. If you have a MAC, you may already have a port.
How can I copy a home shot movie using my Sony DCR-TRV900E to my PC? Is it possibe to copy it directly from the camera I will I need to buy something else as an intemediate step?
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection for stills (if they have one) and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Sony has a tutorial on how to do transfer to computer (Mac or PC) at THIS LINK
1helpful
Want to downlaod to computer via usb, but computer doesn't see device
I'm looking for the driver of sony handycam CDR-TRV22E so that i can transfer the video to my pc. thanx.
You can download drivers and manual for this camera from this page.
Advice on how to do the transfer is on this page. (You need to select Mini DV)
Sony recommend using Firewire instead of USB to transfer video from this type of camera.
This camera has both USB and Firewire (DV) connections. Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other. The USB cable is less standard at the camera end, so search for one that is compatible with your camera.
5helpful
I want to transfer the film taken by DCR-CH52E to computer, is there any one knows the solution? if so please let me know. thank you in advance. regrads
your unit doesnt have usb streaming feature (reason it doesnt have a usb jack). connection would have to go thru ilink (ieee1394) connection. that's the dv interface located left side at the bottom of the battery. it's a plug-and-play connection.so basically you need an ieee1394 card installed in your computer to support connection (refer to computer manufacturer), an ieee1394 cable compatible for both your computer and camcorder (uses 4 pin cable), and a video capturing software like moviemaker (for windows) and imovie (for mac).if you have that then your good to go. hope this helps. thanks:)
4answers
I need a DV cable so I can download my movies from my JVC Camcorder, but my laptop has the USB interface only. Can someone help me find a DV Cable with a USB Interface at the other end? My laptop only...
your camera has a usb connection : wal - mart has general purpose camera to pc cables ( bring your camera to confirm connector size ) also on ebay can get accessory kit for jvc dv cameras .
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
