1991 kawasaki ZXR 750 Logo
Anonymous Posted on Jun 09, 2010
When i try to start my bike up it wont go, just wont fire, checked everything it has spark ect...some days it will go fine, but other days it wont, when i get it going it runs fine, if i turn it off and leave it for 5 mins it wont start again, im thinking its a fuel issue, when i checked the hose going to the carby it had fuel in it so it must be getting fuel, is it flooding? what else can i check, please help me out, thanks
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Jun 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
3366
Points
34
Check the air filter if its clean take the carb apart and clean it with something like b-12 or i use wd-40 on my bike so it wont eat the rubber gaskets
Testimonial: "Ill take a look at the air cleaner, i did clean out the carby somewhat with carby cleaner but not fully cleaned it out, thanks for the help :)"
damo
Level 2:
New Friend:
Night Owl:
An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • Expert 122 Answers
  • Posted on Nov 29, 2011
damo
Expert
Level 2:
New Friend:
Night Owl:
Answers
122
Questions
0
Helped
31684
Points
190
I had a similar problem with my zxr750 and it ended up being a simple fix.
The problem with a number of Kawasakis carburetterd models is that if the carbs are not 100% fueled up the pump cant prime them enough to get it to start.
You need to hard wire the pump to get it to fill the carbs right up and it will fire straight up.
First thing you need to do is find the plug for the pump (Mine is on the right side under the side cover so you will have to remove that first) Then once you have found it up plug it.
The plug that is joined to the pump is the end you need.
Now run some wires straight off your battery terminals( You should already have the seat off if you removed the side cover) long enough to reach your fuel pump plug.
Check the wire colours and remember that black is going to be your earth.
Carfully touch your wires from the battery straight to the plug wires and you will hear the pump start to pump.
Contiue to do it until you hear a difference in the pump - you will hear it load up with pressure .
As soon as you hear this stop it will only take about 4-5 seconds of contious pumping.
Then connect up the plug again a little spray of areo start/start ya ******* and hit the start button it should fire up instantly.
I find that if i leave my bike for any length of time un started its always a bit of a ***** to fire up.
Good luck and i hope this helps you out.
just-ice
Level 2:
Scholar:
  • Expert 75 Answers
just-ice
Expert
Level 2:
Scholar:
Answers
75
Questions
5
Helped
32973
Points
152
Hi
Sorry about your prob - for any motor to work it needs air, fuel and spark. This means checking carby, tank and fuel line and electrical system.
You will need to establish you have fuel being available at the carby at all times + spark when ignition is turned on and motor turned over.
I feel its an electrical fault as when it starts it goes ok and when it stops you have probs getting it going again.
Get an electrical circuit diagram if you can and trace the wiring from the battery to the main switch to the starter - motor and ignition circuits. Make sure all connections are clean and tight
and that you have a good earth connection (maybe more than one)
Check also fuel lines in case you have a blocked air inlet into tank (it would collape otherwise) or a blocked return fuel line - fuel pump is another area of potential failure.
Quick check of fuel system is get a can of Engine Starter (don't know what brands you have whereever you are but we have one called "Start ya Bastard"- usually an ether based spray.
Spray into carby intake and see if engine starts and runs - if it does but won't start without spray its generally a fuel problem.
Cheers
My Suzuki GS 550 L wont start
check the cdi box i think thats your problem if so buy a dyna s 3 for it works great on mine
1helpful
My dr 1990 model wont fire
try pulling the plug, stick a screwdriver in the end of the spark plug wire and hold it to the metal of the bike try starting it if it has fire you wil get a spark. if no spark try checking the points they may have burned out
... good luck
Bike wont start
Install new spark plugs and add a can of seafoam to your gas at the rate of one ounce per gallon to clean your carbeurator.
95 sportster wont start. Everything was running fine until now.
do a basic test .try starting the bike, then take out a spark plug. is it wet or dry? if its dry, no gas getting into the combustion chamber. if its wet, place the thread of the pluged in spark plug against any engine metal, crank the engine and look for a good blue spark. no spark or an orange spark means ignition problem.
2000 Suzuki gs500 won't start
does the bike turn on .. like lights and all? does it role over but just wont fire? if lights and everything come on then it would be a tip over sensor. i had same prob, laid bike down going very slow... got it back up wouldnt start just rolled over if i rememeber right. turned the key of then back on and sensor had reset...... try disconnecting the battery for a few, then reconnect it and try it.
3helpful
Engine wont fire up
Do you have fresh gas in the bike? Try changing the plugs with new ones and check for spark. You can do this by putting the new plugs on the plug wire and grounding it to the head on the engine crank the motor over you should see a bright blue spark. Check one plug at a time. No spark check the ignition wires and coils. As for the oily plugs it could be they are just fouled caused by either flooding the motor while trying to start, bad plugs, week coils, bad gas, poorly adjusted carb's. I would start with the plugs and work my way back to the carbs. Still fouling the plugs after all that start checking the engine, ie compression check ect.
Top kawasaki Experts
Arnie Burke
Arnie Burke
Sean Wright
Sean Wright
Bob G
Are you a kawasaki Expert? Answer questions, earn points and help others
