Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
Anonymous Posted on Jun 07, 2010
Oil leak on riding Craftsman LT2000 (Kohler)
Went to get the Craftsman riding lawn mower out of the scary shed. It looked like oil had leak out onto the dried grass clippings. If mice have eaten through the line, how do I check it and replace it? (It started smoking when I started the engine.)
Anonymous
Level 2:
  • Expert 146 Answers
  • Posted on Jun 07, 2010
Anonymous
Expert
Level 2:
Answers
146
Questions
0
Helped
115928
Points
440
Fortunately, the engine oil doesn't go through any rubber hoses, so they are mouse-proof. The oil probably leaked out through an engine seal. Oil on the engine surfaces would smoke when it gets hot. Check your oil level and top it up if necessary, before you run the engine again. The engine can run fine even with a slow oil leak; you just have to watch the oil level from time to time. The leak could be easy to fix - by tightening up a few bolts -- or expensive.
The gas runs through rubber hoses, though. If mice ate through that, I think you would have smelled the gasoline, and the engine wouldn't run for more than a few seconds. But if you see a severed hose, you should replace it. Take it off and bring it to a mower shop or auto supply shop, and buy something the same diameter. Inexpensive.
Hope this helped! If so, please rate my answer, thanks!
Testimonial: "Whew, you've eased my mind. I'll head out tomorrow and try your suggestions. I really appreciate your input and the fact that you are willing to respond! Thank you!"
Kohler engine oil leak
Could have blown a seal however before checking for that I would check the drain plug and filter seating if you changed the filter. Make sure the drain plug is not cross threaded. You can run a little low but should never over fill. Hope this will help. Most of the time if over filled you will get some smoke as well.
Apr 25, 2014 • Garden
1helpful
Is it ok to use Mobil 1 5W30 in this and also, what oil filter should I use?
Its little light. 10w30 would be better. The oil filter should have no. on it.
3helpful
How can I replace a lost ignition key for a Craftsman LT2000 riding mower
the model number is under the seat on a sticker most riding lawn mowers use the same key the older models used one the looks the same on t=both sides and was short the newer style is longer and has cuts on one side only most any lawn mower shops will have them
3helpful
Changing the oil filter on a lawn tractor
If it is a screw on type oil filter, apply a film of oil on seal, then screw on. If you want to, go ahead and pour some oil in the filter, in my opinion the oil will circulate faster if there is some oil already in the filter.
2helpful
My craftsman 15.5HP kohler riding mower turns over
Try cleaning or better yet, replacing the spark plug. Depending on age and how your tractor was maintained, there are other possible causes.
  • Gummed up fuel system
  • dirty fuel filter
  • defective or misaligned armature/magneto (part that causes your plug to spark, igniting the air/fuel mixture, thus starting the engine)
  • throttle linkage/cable problems
  • low oil level. Some Kohler engines use a low oil shut down sensor which won't allow the engine to run or start to avoid internal damage.
  • Mechanical engine problems
I hope you find this solution helpful. Please rate it thanks for using Fixya!
Craftsman mower with 26hp kohler smokes while cutting.
it sound like you put to much oil in it.if not check vent valve
1helpful
What weight oil should I use for 16 horsepower craftsman engine?
It all depends on the engine you have...all engines except for KOHLER can use straight 30 and Kohler uses only 10W30.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
