Restore unit bookmark
Go to the help button in the upper right hand corner of your course manager. There will be a bunch of questions that appear down
the right hand side. The bottom one should say How do I restore my golfgps. Press that, and press the button that comes up that
says restore. With the gps plugged in and turned on, it will quickly move to say that your gps has been restored. Press Ok, and
turn the gps off , count to five, and turn it back on. Reload your courses, and you should be good to go!
SOURCE: MY GOLF LOGIX HAS WORKED FOR OVER 2 YEARS .
The GolfLogix 7 had a problem that if you did a reset to factory defaults it wiped out the Almanac in the GPS. This is the Table of where the satelites are. Put in a fresh set of battery's....turn it on and put it out in the open sky for 4 to 8 hours. Sometimes this will work. If not contact Golflogix Tech Support. They ill probable ship you a replacement unit.
SOURCE: golf logix for my blackberry ' network error, cannot find host'
If you have verizon, you need to turn GPS services to location on (options, advanced options, GPS) and you need to make all the permissions for the program "Allow"
SOURCE: The unite only stays on for about 15 min and then
Did you check the setting, it maybe on power saver mode?
