20 Most Recent
Garmin Golf Logix GPS Questions & Answers
Will not recognize unit via
MP3 players use the popular USB connection which sometimes produces errors while connecting. These messages are similar to the "Device Not Recognized" error received with various USB devices. Fixing an MP3 player is sometimes specific to the brand, but they are so similar that most can be fixed the same troubleshooting steps.
Instructions
Device Manager
Click "Start" and go to "Control Panel." Double-click "System" and locate the Hardware tab to find the Device Manager. Vista and Windows 7 users can just type "Device Manager' from the start menu.
Locate "Disk Drives" from the list and double-click "Portable Device." If there is an exclamation mark or other error on the device, go to the "Drivers" tab.
Click "Uninstall" and remove the player. Restart the computer and attach the player reinstall the drivers.
Anti-virus conflicts
Plug the player into a different computer to see if it gets recognized. If it does not, contact the manufacturer to find out if it is broken.
Turn off your anti-virus program on your PC if the device works on other computers. Reinstall the drivers using the device manager as described in section 1.
Plug in the player to confirm the connection.
Other solutions
Check the battery level and make sure the batter is not low or depleted. A low battery will sometimes prevent the player from connecting. Let it charge from the power cord, if necessary.
Verify that you have at least Service Pack 1 installed. Go to the Start menu and type "Run." Press Enter.
Type "Winver" in the box and press "Enter." The Windows version will be displayed along with any installed service packs. Download a service pack from Microsoft, if applicable.
Remove the player from the USB port and push a pin into the reset hole located on the bottom. Reconnect to see if the problem is resolved.
Check the connection to make sure it's secure. The cable should fit firmly into both the player and the computer. Connect to a different USB port if you have one available.
Download updated firmware or use the MP3 Recovery Tool provided under Resources (mp3 players).
Tips & Warnings
A bad cable will sometimes prevent a good connection. Use a different one to isolate the cause.
I did a reset and
you should run the GolfLogix Course Manager Setup Wizard to enable you configut=re all the options. also make sure you have the latest firmware installed. please
go here for further details.
MY GOLF LOGIX HAS WORKED FOR OVER 2 YEARS .
The GolfLogix 7 had a problem that if you did a reset to factory defaults it wiped out the Almanac in the GPS. This is the Table of where the satelites are. Put in a fresh set of battery's....turn it on and put it out in the open sky for 4 to 8 hours. Sometimes this will work. If not contact Golflogix Tech Support. They ill probable ship you a replacement unit.
Can not find file path for ser2pl.sys to open
Its a registry issue. Install the driver off their website on another computer (the legacy driver, not the one that says first download driver. its on the same page) and get that ser2 file from your system 32 folder, copy it to the other computer.
My Golf Logix GPS says scroll up to first hole but
o to the help button in the upper right hand corner of your course manager. There will be a bunch of questions that appear down the right hand side. The bottom one should say How do I restore my golfgps. Press that, and press the button that comes up that says restore. With the gps plugged in and turned on, it will quickly move to say that your gps has been restored. Press Ok, and turn the gps off , count to five, and turn it back on. Reload your courses, and you should be good to go!
I have a golflogix /Firewall Problem
THat error means you need to download the updated software, you have the 3.0 software. go to golfgps.com, choose the gps8, and download software, and do the second download software link.
Reboot for garmin golf logix
Restore unit bookmark
Go to the help button in the upper right hand corner of your course manager. There will be a bunch of questions that appear down
Unit does not respod to course manage after updating software
says restore. With the gps plugged in and turned on, and with fresh batteries in it, it will quickly move to say that your gps has been restored. Press Ok, and
turn the gps off , count to five, and turn it back on. It should now recognize your unit again.
2008 GolfLogix suddenly gives very bad measurements
