THANKS WAS "RACKING "MY BRAIN TRYING TO FIND SOME KINDA FIX!
Ditto with FPD2485W monitor. Thanks for the unplugging solution, but yeah, hope we find a permanent solution
I have the same problem as well.... unplugging definitely helps. But we shouldn't have to unplug the monitor every 2 weeks. Have you found any updates on this problem? I imagine there are several of us out there...
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
This is a common problem with many LCD monitors. The
printed circuit board that provides a stable voltage for the monitor to operate
from starts to fail. The PCB can be replaced, when/if they are available, or repaired
in most cases at a much lower cost. for more information on this email me at
[email protected]
SAME PROBLEM, CAN FIND NO SOLUTION.
The same delay issue with Gateway FPD2275W. Used unplug suggestion.
It works for now. Unfortunatelly do not understand anything about fixing the computers. Will be very good if somebody will find permanent solution.
Alex
Same problem, unfortunately.
same problem, here too.
