Im interested in buying the i-931 lasonic Boombox, but am curious as to whether it can be used in Australia?
The mains plug has a North American (two straight pronged) end, and there is a DC 12volt cable insert on the back of the system. There is also a switch that switches between "AC" and "DC".
Would I need an adapter, and a transformer? or neither? or a dc plug?
Would our 240v blow it with just an adapter?
Hopefully you're able to help me out.
Peace out.
On the back of the panel peel the label off and you will see 110/220V switch Selector. If your country require 220V power requirement, please switch to 220V and you only need to purchase power plug adapter which fit in Australia.
if you connect the boombox direct to the your mains of 240v, the appliances will blow up , to avoid that you need a step down transformer to connect the boombox before it goes into the mains source. you do not need any adapter, only if you want to use battery that is when you to swicth to 12v
There's nothing special about the original power cord, so I'd go to Radio Shack and get it for $8
http://www.radioshack.com/product/index.jsp?productId=3875429
Or you may have an unused one from other device lying around the house.
