20 Most Recent
Lasonic MP3 Player Questions & Answers
How to tune radio
Here is the link to the user manual
http://www.lasonic.com/store/pc/catalog/mp3%20player%20manual%20fm.pdf
MP3/Mp4
Dear All
My ACTIONS HS MP4 USB Flash Disk has a lean screen. i switched on for the first time and the top edge slant from left to right. checked the Menu Options but no luck. i know you can scare up a normal monitor screen but dont know how to sort this one out.
thanks for any help
bret
I have lasonic mp-04gs, i
Hi, I think you need to update the software on MP3 player. Or try using windows media player (WMP) . I use it and it works fine. Good luck
Wont turn on
Press the reset button. Charge it in a computer.
Will not turn on, i know there is music on there.
Hi
Try and reset the player by inserting a pointed object inside the small hole, press and hold for 5-10 seconds to let the player reset. If this doesn't work then connect the player with the computer and let it charge for a while. Now go to control panel-> administrative tools-> computer management/system management-> storage, check if you are able to see the mp3 player here. If it is visible then try a reset and try again. If not then reset the player while it is connected with the system. This will resolve your issue.
Hope this helps...
Daniel
How do you turn this on?
it is the play button, hold it pressed until the lcd reacts or powers up, be sure that there is batteries.
