What may of happened if that you got the lacquer finish on the electromagnetic wire to heat up and come apart. At low volume they will still have an electric connection. Because the wire physically came off from the inner housing of the voice coil it is in contact with the side wall of the speaker magnet and is proned to causing a short between coil sets. Your probably running subs with a 4 ohm impedance and when your coils short it acts more like a 2 or 1 ohm speaker. This is similar to whats called a dead short. Since the Independence is dropped to 2 or 1 ohm it is the resistance equivalent of having 2 or 4 subs attached to your amplifier which caused the final transistor bridge to heat up and it can get hot almost instantly. Check your amps outputs individually on a single speaker that you know works perfectly. If your amp does not trip the thermal protection you most likely cooked a speaker beyond usable condition.
I took my amp and subs out of my vehicle and set them up in my cousins car and everything sounded awsome, like nothing was wrong at all. We took a cruise for an hour with it rockin the whole time and not one hickup. The only difference between his setup and mine is im using 4ga. he's using 8ga. he has an aftermarket deck wich gives him audio jacks v.s. me using the converter. Thats about all the differences there are. Any idea on whats happening?
