Question about Vtech Cordless 6041 Phone
The Vtech phone has continued to flash on and off with no dial tone and no trouble shooting resolve in the manual. Doesn't matter if I unplug the power source or the jack or take out the battery for a few minutes or press the find handset button...nothing works to rest this phone. Very annoying. Please help me so I can use my phone again. Thanks a bunch!
    Top Expert:
  • Vtech Master
  • 29,864 Answers
Perhaps your phone line is down.
Posted on Oct 03, 2017
SOURCE:
SOURCE: Not Registered
I had the same problem and this procedure fixes it! First, unplug the power to the main base (answering machine) for 20 seconds. Plus it back in. Put the phone that says "not registered" in the main answering machine. It will say "press the find handset for 4 seconds". Do that. It will run thru a series of stuff and will find the handset. It works! Rich (jambones.com)
Posted on Jun 01, 2007
SOURCE: Problems with C110 & A110 Vtech Mirage Dect Home phones
Have strangely got the same problem - about the same time you posted this, but intermitently. I have isolated that the problem is in fact the handset itself, not the base unit. I eliminated a problem with the base unit by a) registering a different DECT phone to it. - The base still works fine. b) Leaving the handset switched off for an hour or so (press and hold the "OK" botton to switch off / on); then whislt it was working, registering the handset to a different base (Base 2). And guess what, after 30 mins the "BASE 2" message started flashing on the faulty handset.
So, if you already have an A110 extension handset, make sure it's also registered to base 1 and maybe try to get just the handset repaired via VTECH. (or just buy a new handset if they are available).
Posted on Jun 26, 2008
SOURCE: vtech phone problem Model # LS6117-5 DECT 6.0
take out battery for a few seconds then put back in. My phone just did the same thing and it kixed it. Not sure why it happened though
Posted on Jan 20, 2009
  • 52 Answers
SOURCE: no dial tone
I would contact your phone provider. It could be a coinceidence that the dial tone stopped working.
DSL does not require dial tone to work.
Posted on Sep 12, 2009
SOURCE: My vtech 5825 screen says NOT REGISTERED and does not work
Place the handset in the charger and press find handset for 4 seconds.This will register the handset. do the same for other handsets.
Posted on Sep 20, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
How to change a vtech phone to tone
Enter the model of your VTech phone into the search box at http://www.vtechphones.com/support/general/manuals to download a copy of the manual. The manual will explain how to switch your phone between pulse and tone dialing.
Nov 21, 2013 | Vtech Lands Phones
My Vtech cs5121 cordless phone has no dial tone
Vtech phones are junk! I have had many trouble calls for no dial tone,only to find out the Vtech phone is the only one they have,and it is defective.(It really DOES pain me to bill someone 91 dollars to tell them their 21 dollar phone is broken-always try another(preferably hard-wired) phone before calling the phone company!
Dec 30, 2012 | Vtech 5.8GHz Cordless Phone with Digital...
How to prgram the vtech 5.8 dial tone to touch tone
Since you declined to specify the model of your VTech 5.8GHz phone, I can only suggest that you enter it into the search box here to download a copy of the manual. The manual will describe how to switch between pulse and tone dialing.
Mar 05, 2012 | Vtech 5.8GHz Analog Cordless Phone
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    I unplugged vtech tel to move to another location-now i have CL flashing and none of the phones have dial tone-how do i fix-thank you very much for your help
    The main unit with the answering machine needs to be plugged into and outlet and also plugged into a working phone jack. The other units just plug into an outlet and speak to the main unit wirelessly. Make sure the main unit is plugged into a phone jack.
    Jan 17, 2011 | Vtech Digital Cordless Telephone VT-2568
    No dial tone
    Sep 04, 2009 | Vtech Lands Phones
    Vtech flash won't turn on
    trie unplugging it then pluging it back in.
    Feb 22, 2009 | Vtech V.Flash Home Edutainment System
    No dial tone
    did you try unplugging the phone for 10 min. and try that
    otherwise it could be on the outside box
    Feb 07, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
    Dial Tone but won't call out.
    I just had the same problem. Try unplugging the plug from the electrical outlet for the home(base) unit and plugging back in. Fixed my problem right away.
    Jul 26, 2008 | Uniden Cordless Phone
    Vtech Cordless 6041 Phone Logo
    88 people viewed this question
    Top Vtech Lands Phones Experts
    Marvin
    Marvin
    Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
