Televison & Video Logo
Anonymous Posted on Apr 05, 2008
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
I have purchased a DJ Tech Direct Drive USB Turntable for transferring my vinyl LP's into CDs. I want to hook it up with my Sony Mini Hi Fi MHCRG495 enroute to my Mac G4 so I can use the three stereo speakers.
Do you know what kind of adaptor I need ? I was looking at an RCA Scart Plug Adaptor but wasn't sure if that was the right thing to buy.
  • Anonymous Apr 30, 2008
    Sorry for the delay with my response. Your suggestion has worked well. Will soon be attempting my first trial at creating good quality CDs from LP vinyls. Thanks for your support, much appreciated.
A
Anonymous
How do i connect a usb cable to a turntable
Brandon Higa
Level 2:
Scholar:
  • Expert 119 Answers
  • Posted on Apr 05, 2008
Brandon Higa
Expert
Level 2:
Scholar:
Answers
119
Questions
0
Helped
59290
Points
218
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
  • Brandon Higa
    Brandon Higa Apr 30, 2008
    Great! Glad to hear it, and I'm sure you are too! ;^)
Sony PS-FL7 direct drive turntable. When start button is pressed it illuminates but turntable won't rotate. All other functions work as they should.
'Direct Drive' appears to mean something different to Sony unless the belt is for another function.
https://lptunes.com/products/sony-ps-fl7-ii-ps-fl7-ii-psfl7-ii-turntable-tonearm-belt-replacement
Service Manual
Sony PS-FL7 Stereo Turntable System Manual
Vinyl Engine
https://www.vinylengine.com > library > sony > ps-fl7
Sony PS-FL7 owners manual, service manuals and schematics are for reference only and the Vinyl Engine bears no responsibility for errors or other inaccuracies.
"); background-repeat: repeat-x; display: inline-block; overflow: hidden; position: relative; background-size: 14px 11.4px; height: 11.4px; width: 68px;">"); background-repeat: repeat-x; display: block; background-size: 14px 11.4px; height: 11.4px; width: calc(56px);"> Rating: 8/10 · ‎ 4 reviews
SONY PS-FL7 service manuals download
NoDevice
https://www.nodevice.com > ... > Vinyl Players > SONY
SONY PS-FL7 service manual (Vinyl Players) in PDF format will help to repair SONY PS-FL7, find errors and restore the device's functionality.
Turntable speed stuck at 45
You should visit the website of the makers or phone them for advice as it's new. It may need to be replaced.
4helpful
I purchased a Vibe Sound 3 Speed Turntable w/USB to PC and it does not have sound when I plug it in to the USB. The record is spining and I can hear sound from the needle.
The turntable won't make sound on its own when connected to the USB port. There are probably some drivers on the CD packed with the table that you'll need to install, and then you'll need to select the device in the Windows sound control panel. You'll also need some software to record and edit your vinyl if you want to transfer your records to CD.
I'm not familiar with the brand of turntable you have, just the ION, but it probably came bundled with some application on a CD. The ION table comes with Audacity, as well as some trial versions of audio processing (click and pop filter, hiss remover, etc.). Audacity is free, open-source software you can download here if you want it. It allows you to listen to and record your vinyl audio as wave files, then edit it, split tracks, add effects, and other fun things.
Simple Tech HD failing- takes 4 hours to tranfer 512 MB!?
Not exactly a solution but I have had the same problem with one of these Simple Tech Signature Mini 320's for a while. Real finicky. Will only be recognized on direct connected to MB USB ports and even then with Win 7 or XP I get the "This USB device can perform faster if you connect it to a Hi-Speed USB 2.0 port." no matter what ports I connect it to. While having this issue on this "main" computer I have previously connected it to some other computer (don't remember which, now) and it connected at 2.0 speed. What's going on??
Have linked it up to my normal surround hi fi system but no sound. No sound either when connected to my pc.
You asked this question in the TTUSB category. Do you have that turntable and how are you connecting it to the surround sound?
The turntable has a USB port and corresponding EZ Vinyl software that lets you monitor the output of the turntable. Then you can connect the computer sound card to speakers to hear what is playing.
Carl
EVERYTIME I PLAY A RECORD IT DRAGS TO PICK UP SPEED
Are you sure you have a Technics SL1200MK2 Direct Drive Turntable? If so, then there is a major problem with the drive system. This can only be diagnosed and repaired by a qualified technician.
If your turntable is not the Techics SL1200MK2, and you have no idea what turntable you have, look at the model's label, if it says BELT DRIVE - this is the reason why it drags to pick up speed. If it says DIRECT DRIVE, then take it to a service center for repair.
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Turn on turntable the vinyl button doesnt wrk
This is a tough one. Sounds like physical damage. You'll need to take it to a service center for repair.
- OPTiC
Pioneer DJ Repair Videos
Pioneer DJ Repair
Pioneer DJ Parts
DJ Parts
DJ Equipment Sales
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
