The fridge compartment on my fridge freezer freezes all the time , the pump does not appear to stop running, is there possibly a thermostat on this model or has it an electronic circuit board
Either the thermostat is set to high or you need to replace the thermostat.adjust it to 1/2 way position position and if temp is to cold and it doesnt want to switch off, it means the thermostat is faulty.
The super is for super cold and on that setting it might not cut off. If it's not on that setting then that control is probably bad. Your model number is needed for more information. It's usually stamped on a small tag in a visible location on your appliance. Refrigerator- Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
You said, you recently had a problem with my Candy fridge freezer (it defrosted overnight and wasnt cooling at all) and a repair
shop diagnosed a thermostat problem. I have replaced the thermostat,
Now the freezer freezes without any problems but the fridge does not go
cold at all.
Also the compressor is running constantly
This is my first thought
Fresh Food temperature is too warm. Freezer temperature is satisfactory. 1. Fresh Food control is set too warm. 2. Set fresh food control to a colder setting. Allow 24 hours for temperature to stabilize.
3.Then see if you do not have your freezer articles packed full up to the top, or covering the cold air vents usually found in the rear of the freezer compartment.
The fridge and the freezer share the cold air so the air must not be restricted from travel form the freezer to the fridge and back! This would also cause the compressor to run none stop trying to cool the fridge! So check your air vents in the freezer. I'll bet you did not know they were there ! Most of us never notice! Hope this works for you. Please let me know that one of these solutions worked for you! or if you have any questions. Thank You, huuum Please remember to leave a rating!
