One red light code E73 appears on screen
Your xbox is going to die..
but there is a way that you can play it.just heat up your xbox for couple of mins.then try again.it works.
every time you see E73 error just do this
for more help email me how to do.
[email protected]
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
