How to set the clock
Here is a link to the owner's manual to that stereo which will tell you how to set the time:
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/130/130DEH1600.PDF
Press the source button till clock display appears.
Press function and audio button (top right on 4400)together until clock display blinks, us side buttons and up and down to set. Press Audio button to end.
SOURCE: set clock on deh-4700mp cd player
With your key on, press and hold the Source button until the unit turns off. Then press and hold the FUNC button to enter the settings menu. Press and release the FUNC button again until you get to the clock display. Then use the deck's left and right control buttons to select whether you're adjusting hours or minutes, and use the up and down buttons to make the adjustments. When you're done press Source again.
SOURCE: clock
To set the clock on the Panasonic DEH-1600 car stereo, follow these instructions:
SOURCE: clock setting
Setting the Time
This is the mode for setting the time on the unit’s clock display. (Refer to page 51 for
details concerning the clock display.)
As soon as you switch to “Minute”, the seconds start counting from 00.
1. Press the FUNCTION button and select the Time setting mode in the InitialSetting Menu
always select “OFF”.
2. Select “Hour” or “Minute”
with the < / > buttons.
3. Set as desired with the ^ / v
buttons.
