20 Most Recent
Pioneer DEH-1600 CD Player Questions & Answers
Thumping sound
You either have a bad ground from your amp to the vehicle or a problem with the amp. Where is the amp grounded? Do not ground an amp to a seat bolt or side panel on any vehicle. The weld points on the car itself cause issue with ground. Take the ground wire directly thru the bottom panel (floor) Check befor you drill! don't hit a wire/fuel line, etc. That will give you a solid ground. Keep your ground wire length to a minimum. 18" or less, and use the same gauge wire for ground as you do for power. Hope this helps
Pioneer deh-1600
i know theres many of people out in this world using google or what ever and need this so here it is for pioneer DEH-1600
yellow- Batt/mem. 12v
red- ignition/acc. 12v
blue- power antenna
black- ground
orange- positive dimmer
purple-RR +
w/b - RR -
green-LR +
w/b - LR-
grey-RF +
w/b - RF -
white- LF +
w/b - LF -
Dont know how to set the clock.
turn your unit off by pressing the SRC button. then press the clock button (clock appears). press the audio (or function button) and then the hour blinks. press up or down to change setting and left or right to switch from hours to minutes. press audio button. wallah!
How do I set the
-turn the radio off
-press the "A" buttom (right on top) for a while
