Hi. my laptop was able to detect wifi connection but was unable to access internet..i downgraded from vista to xp..my frends laptop ( toshiba) was able to connect to the wifi connection..my wifi is on..what should i do? thnx
Check your wireless key or try a new driver from dell here
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&ServiceTag=&SystemID=INSPIRONI6400/E1505&os=WW1&osl=en&catid=&impid=
I did two things to resolve this issue
1. Downgrade the router to a lower version.If your router is Netgear WGT624 v3 use this link to downgrade your router
http://www.davejackson.com/life/cant-access-wifi-with-ios-6-on-iphone-with-netge ar-wgt624v3-fix/
(this help to avoid getting a errro message "Unable to join network")
2.
Reconfigure you Wifi network by going to setting ---->under choose a
network---> others-----> Enter your SSID name (seen at the back
of your router) ----->under the security tab selet the same
encyrption standard as that of your router which you can see when you
log in to the router (usually router IP 192.168.1.1) ---->setup
------>wireless setting----> security option. This one helps you
to join your home wifi as soon as you enter your home.
I hope this one works as it worked for me
I was able to log on wireless but now I can not. System shows I am connected to wireless but will not log on to any site.
I can log on using cable.
gets connected to wifi but cannot access the internet???
