LeapFrog Tag Reading System Logo
A
Anonymous Posted on May 14, 2010
How to change battery on leapfrog tag? Trying to download new books from the on to tag but it says there is a problem with the connection. Can you help?
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 29, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
8156
Points
18
In order to change the battery on the tag "reading pen" turn it over and there is what looks like a flat head screw head on the back of the tag, it should be white. Give that a quarter turn and the back should pop off, ours was kind of tough to get off but after the back comes off you can replace the 2 AAA batteries. I believe the "pen" has to be turned on to connect to the computer so this might fix your connection problem also.
  • jackie15414 Dec 31, 2010
    I got the white part off but I can't get the batteries out because the purple part is holding them in. What do I do next??!!
Leapfrog tag reader
Hi, you can download allof the software from the LeapFrog Web site
www.leapfrog.com
I hope that this helps?
Apr 28, 2014 • Toys
Pen not working
you should just buy a new one
6helpful
Having and issue with the audio download on the Leapfrog Tag system. I have Leapfrog Connect installed on my Mac. Audio for books previously downloaded and newly downloaded are not able to be put on pen. I...
Just got this from LeapFrog. Worked for me, although it toook a couple of attempts.
For Macs:
Please try downloading and running this tool and connect the Tag Reader when prompted:
http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
For Windows machines:
1. Close the LeapFrog Connect application.
2. Double-click on this link http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe then click "Run."
3. Click "Unzip" to extract the files.
(You will be asked for a location to save the files. Save them to your Desktop or to another folder that you can easily find.)
4. After the files are extracted, find the "LeapFrogTagFixTool" folder on your Desktop (or where you saved the extracted files).
5. Open the folder and double-click the "TagFixTool.exe" file to open the LeapFrog Tag Repair Utility program.
6. Connect your Tag Reader to the computer. (Make sure your toy is powered on.)
7. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
8. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Jul 26, 2012 • Toys
2answers
The Save to Tag button on the leapfrog connact application does not do anything and so none of the audio will download from the library to the actual tag device
mine is doing the same thing. it's brand new. my daughter got it for christmas yesterday. i've even tried it on my husband's macbook. both our macbooks are up to date and her leap pad works. i'm about ready to take this stupid thing back to the store. it synced all the books except for her tangled book and will not sync again. i've even tried to restore back to factory settings and it won't even do that. i've deleted and reinstalled the leapfrog connect app 3 times. also seems that the stupid pen sucks down battery juice. i've put brand new lithium batteries in the pen and after 2 hours the pen is acting like it's dying and the only thing we've been doing is trying to sync it.
Hi what does error code #1096 fault detail null mean?
Thanks for using Fixia.
Please try below instructions if they help .
You will want to use the LeapFrog Connect Tag Fixing Tool to see if you can resolve the issue. The instructions for Mac, and PC are listed below:
PC instructions:
1. Begin with LeapFrog Connect closed
2. Click here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.exe for the download executable file.
3. A File Download box should pop up. Select "Run"
4. You will be prompted for a location to download the program to, you will see a message "Unzip to folder"
5. Click Browse and select your desktop as the location to save the folder
6. Click "Unzip"
7. This should create a folder on your desktop named "LeapFrogTagFixTool
8. On XP: Open the folder and double click on the TagFixTool to open
9. On Vista or Windows 7: Open the folder and right click on the TagFixTool and select "Run As Administrator"
10. Connect the Tag Reader or Tag Junior to the computer and turn it on
11. Click the button "Click once to fix your Tag Reader or Tag Junior"
12. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Mac instructions:
1. Download the LeapFrogTagFixTool.dmg and mount the image. File is located here: http://lfccontent.leapfrog.com/cs/tools/LeapFrogTagFixTool.dmg
2. Drag the FixIt application into your Applications folder.
3. Close the LeapFrog Connect application (if it is open.)
4. From the Applications folder, double-click the FixIt application file to open the LeapFrog Tag Repair Utility program.
5. Connect your Tag Reader or Tag Junior to the computer.
6. To start the repair process, click the "Click once to fix your Tag Reader or Tag Junior" button.
7. Once the repair process is complete, follow steps printed on the screen to close the program and open LeapFrog Connect.
Note: Please be sure to be signed into your admin account and are connecting to a USB port directly on the computer, not a port on the keyboard or other hub.
8helpful
Top LeapFrog Toys Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a LeapFrog Toy Expert? Answer questions, earn points and help others
