Technics SL-1200 Turntable Logo
A
Anonymous Posted on May 10, 2010
SL-1200 Turntable: My brand new Technics 1200 MK2 sounds wobbly when ...
My brand new Technics 1200 MK2 sounds wobbly when I play it and the lights dim in and out...as if the power wasn't flowing evenly. this is the 2nd one I bought. The same issue happened with the 1st one so I took it back because I thought it was defective and purchased a new one from another store. same issue.
  • james000111 Jul 07, 2010
    did you get them wet?
Styluscity
Level 2:
Champion:
  • Technics Expert 271 Answers
  • Posted on Sep 13, 2010
Styluscity
Technics Expert
Level 2:
Champion:
Answers
271
Questions
0
Helped
94525
Points
381
Try plugging it into a different power point. The problem is with the power supply fluctuating. You can eliminate that with a UPS, here is a link to wiki http://en.wikipedia.org/wiki/Uninterruptible_power_supply
[email protected]
My turntable won't play at 33rpms. tried the pitch adjustment with no success. my turntable is a Technics model#SL-35
First, I'm not a Technics tech.
* Normally I would suggest to check for warranty, but this unit is outdated.
* Try to contact ; https://www.technics.com/us/support/
*** The following is for information only.***
* The following vid shows the speed switch on the left. If it's not tracking then there may be a problem in the selector switch, sync tracking, or motor drive.
* You may want to check the "window" or sensor of the the speed sync light (the orange light). Wipe down the lamp and the peep hole where the sensor is located (on or near the lamp)
* Wipe down the outer edge of the turn table to clean the metal "dots" or "bars" on the rim. This is what the sensor reads to determine speed.
* Speed controls and direct drive turntable are not customer serviced parts (other than replacement of the component).
* Example of play; https://www.youtube.com/watch?v=YUaywfmnvt0
* Closer look at auto play feature; https://www.youtube.com/watch?v=A7RURSnbSz4
* SL-1510 Mk2 repair; https://www.youtube.com/watch?v=Unf0rtQI0Us
* SL-1900 repair; https://www.youtube.com/watch?v=k0HTskP4Wak
* SL-1210 repair; https://www.youtube.com/watch?v=dKpQ3j6WzXQ
* SL-23 repair;https://www.youtube.com/watch?v=hTTLkQosBzc
* Repeating Return problem; https://www.youtube.com/watch?v=-tel1eKu9YI
* SL-1200 Speed changes(sync); https://www.youtube.com/watch?v=jVws5t25XPk
* SL-1300 Speed problem; https://www.youtube.com/watch?v=0Dg-S0QPaek
* SL-1200 Very DEEP level repair; https://www.youtube.com/watch?v=mEvOpKsJMRo
Aloha, ukeboy57
Distorted sound on Technics SL-1210 mk2
Hi, check to make sure the headshell is fitted properly to the tone arm and that the stylus is not damaged. Cheers john. Styluscity
SL-1200 Turntable: I own two Technics SL-1200mk5 turntables. My probl...
Hi, could just be platter not fitted hard down on spindle. I suggest you remove the platter and place it upon a dead flat surface to check to see that the platter is flat. If it is flat refit to turntable ensuring it is hard down on the spindle. If bent discard and replace with new platter.Platters can be ordered for all model 1200/1210 from [email protected]
Plastic top for technics 1200 mk2 turntable
Hi, What do you mean by this pls, you need a new top or how do you fix a broken one?
Thanks Mark H (superstar DJ)
1helpful
Technics 1210 MK2 - unstable/uneven speed problem
Since this is a direct-drive turntable, it isn't a slipping or stretched belt. You will need a technician with a couple pieces of equipment and some experience/training to find the source of the problem. I suspect the part(s) will be the minor cost of the repair.
Sl 1200 mk2 no sound comming out new needle
It sounds like the rca (phono) leads also check your cartridge.
Regards.
http://www.audiovisualservices.info/
10helpful
2answers
How old is my Technics SL 1210 Mk2
Here's some information for you. Since your unit is a SL1210MK2, it may be harder to determine the age of the unit:
It is possible to tell the year (and the month) when the SL-1200 was manufactured from the serial number on the back or bottom of the turntable. SL-1200 serial numbers are in two different formats, depending on the date of manufacture. It isn't exactly possible to determine the decade in which the SL-1200 in question was manufactured, as the serial number contains only the last digit of the year. If the year digit is 8, the turntable may have been manufactured in 1978, 1988 or 1998. If the year digit is 0, the turntable may have been manufactured in 1980, 1990 or 2000. One rule of thumb is that old-format serial numbers belong to SL-1200s manufactured during the 1970s and 1980s, while new-format serial numbers belong to SL-1200s manufactured during the 1990s and beyond.
Old-format serial number: NHOJF20765 (SL-1200 manufactured 1982)
The first digit shows the year when the SL-1200 was manufactured. These serial numbers contain no indication of the month of manufacture. It should be noted that serial numbers in this format contain no letters following digits.
New-format serial number: GE4FB001154 (SL-1200 manufactured June 2004)
The first digit shows the year when the SL-1200 was manufactured, while the month of manufacture is indicated by the letter following it. Months are coded as letters between A and L inclusive; A indicates January, B indicates February, and so on.
In addition to the above, all the SL-1200MK2s from the 70's and early 80's have a 4 inch diameter plate where the RCA and ground wires enter the chassis in the rubber base of the unit. The later models have a smaller hole through which the wires enter the unit.
TWEAK A/V LAB
www.DJPROLAB.com
2answers
Technics 1200 MK2 displaying irregular speed to include dragging and slowing
It sounds like the pitch slider needs to be replaced...
Mikey's Hook-up
88-90 North 6th
Brooklyn, NY 11211
Cover insured UPS charges both ways and you will get sorted.
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
